Question about Epson CX8400 All-In-One InkJet Printer
Carrier jams to the left hard,when i turn it on
Carrier jams hard against left wall of printer,get error cant do a thing
Mine was doing this today and I found a push pin had fallen into it and was inside where the ink slides. I couldn't see it until I got a flashlight in there. Once I removed it, all was good and it works well again!
Posted on May 06, 2009
  • Epson Master
  • 5,568 Answers
I don't know your printer so this may not be the problem.
Check inside with a flashlight and look for a plastic band laying in the wrong place; this is a clear ribbon with very fine vertical lines on it that the printer uses to 'count off' its position. Normally, a printer will go to one or the other end so it knows where to start counting to determine where it must go and identify its arrival at a particular character position as directed by the software sending the data.
These bands can break or become contaminated so it is no longer clear where the carriage is or where to go next.
If you find such a band and it is intact, clean it gently with glass cleaner and soft cloth or paper towel and reinstall it, threading it through the slot in the carriage where the optical path is located that 'reads' the stripes.
All printers using this type of technology will have one static hook for one end and a second that is a leaf spring with a hook for the other end of the band.
Posted on Sep 30, 2008
Lexmark 4200 error code 1200
Hi. Please follow the procedure below on how to resolved this issue
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Jul 07, 2010 | Lexmark X4270 All-In-One InkJet Printer
Error #1200----help cannot receive Fax but can send them
Hi There
Hope this resolves your issues.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Feb 01, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 shows error message #1200 and to consult User Guide. We do not have one and do not know what error #1200 is.
1. Turn off your all-in-one
That's all the information I could find.
Jan 15, 2010 | Lexmark X4270 All-In-One InkJet Printer
What is error #1200 mean.
Oct 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error #1200 appears on screen
Jul 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
The ink carrier has a clear carrier jam message...
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, then its a hardware issue and you should contact Lexmark for replacement of the printer.
Apr 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error #1200
the printer is stalled.
2. Unplug your printer from the wall outlet.
4 Plug in your printer
2nd option Cartridge Error: 1200
7. Plug in your printer
8. Press power to turn it back on. you can equally check this link for full and detailed description of the problem and solution http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS23485
Sep 09, 2008 | Office Equipment & Supplies
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Carriage jam
This can be many things, but inspect the paper path for anything stuck. remove the cartridges with printer off and see if you can manually move the carriage you may need to force it a little but not allot, sometimes it may jump a gear causing this error.
move the carriage away from home position and turn on, the printer should reset the carriage position.
hope this helps
Jan 07, 2008 | Office Equipment & Supplies
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
