Question about TruTech PLV16320 Television
Trutech how can i get channells 3,4 without remote
    President:
  • 814 Answers
You should be able to find the answers for this problem in your owners manual. They should have a section on how to operate your television without using the remote.If you cannot find the answer there , try calling these telephone numbers for TruTech technical service : 1-888-252-6252 and 1-800-252-6123. I hope this helps you with your problem.
Posted on May 17, 2009
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
Comcast dta remote codes for trutech klv3112
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
Good luck to all!
Jan 10, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Cant channel buttons on tv
If you can't change channels by the remote or the buttons on the set then the Main Board must be replaced. This is probably more costly than you would like to spend on that model of set.
Oct 29, 2009 | TruTech PLV1615T 15 in. LCD Television
Big mistake, bought a Trutech TV w/DVD now mult. problems
sounds like a defect. if you gought it recently, i would return it. there is nothing to repair that.
Oct 16, 2009 | TruTech TT320
Channels blockec
You can call TruTech technical service at these telephone numbers for help with you problems. 1-800-252-6123 and 1-888-252-6252. I hope this helps you with your problems.
Mar 11, 2008 | TruTech PLV16320 Television
Trutech dvd-r
Set it for antenna and use the single channel it sends to your TV, which is the only signal coming out of your cable box
Feb 18, 2008 | TruTech T650-DR DVD Recorder
Trutech t2000-d remote control codes
I have the same problem as well. I bought 3 different remotes and not one will work with the tv. Although all 3 gave Trutech codes (1116, 1504, and 1713).
Feb 02, 2008 | TruTech PLV16190 Television
Not being able to get the tv back to channel 3 without remote
Trutech is an oddball brand made for Target by several companies. The chances of finding a functional aftermarket brand is slim.
Nov 11, 2007 | TruTech PVS2119 19 in. LCD Television
TruTech 20" Flat Panel CRT Television
Is there anyway you can lockout channel 5 or delete it and then scan again? If this do not work after it programs the 3 chan. then see if you can manually add the other and then try to surf throu with remote.
Aug 22, 2007 | TruTech PLV16320 Television
TruTech PLV16320 Television Logo
49 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
