Question about Philips HDD1630 MP3 Player
Philips my player won't reset i press the butten at the bottem and it only shuts down
  • Anonymous Oct 28, 2008
    My phillips mp3 2GB player will not cut on at all it keeps saying repair needed
  • 4 Answers
Try pressing the off/on button and the volume up button at the same time.
Posted on Oct 18, 2008
When I press "Music" on the menu, the unit
Welcome to Fixya. If your player freezes and you already press the reset button it seems that the issue is the you can try to update the software and see if it will fix the issue. Can you provide the operating system of your computer.
Thanks
Jul 19, 2011 | Philips GoGear SA5285/37 Digital Media...
Philips GoGear Mix MP3 player. Copied MP3 files to device.. Fully charged. When I turn it on, it starts updating to 40%, hangs, and shuts off. Help
I had the same issue reset the player and continue holding down the reset button. Then turn the power on while still holding the reset button it'll shut back down, but when you turn it back on it should work.
Jul 04, 2011 | Philips GOGEAR SA6045 MP3 Player
My model is Philip SA1MXX02W/97 GoGear Mix 2 GBMP3 Player.When I on it, it shows updating 20 percent, then updating 40 percent ; hang there for few seconds and suddenly off by itself. Pls help.
It shows there is some problem with the inbuilt device firmware.The only solution is to do a reset on your device.Please follow the instructions below to reset your Philips SA1MXX02W/97.
1.Insert a pen tip or other object into the reset hole located at the bottom of the GoGear Mix. Hold until the player shuts down.
If the reset option is unsuccessful, follow the steps below to recover the GoGear Mix with the Philips Device Manager:
1.On your computer, select Start >Programs > Philips Digital Audio Player > GoGear Mix Device Manager > Philips Device Manager to launch the Philips Device Manager.
2.Turn off the GoGear Mix before you continue.
3.Press and hold the volume button + while you connect the GoGear Mix to your computer.
4.Keep holding the key until the Philips Device Manager acknowledges the GoGear Mix and enters the recovery mode.
5.On the computer, click the Repair button and follow the instructions of the Philips Device Manager to complete the recovery process.
6.When the recovery is completed, disconnect the GoGear Mix from your computer.
7.Restart the GoGear Mix.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 26, 2011 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
How to change the time on my Casio F91W watch?
first you push the bottem left butten three tmes than push the top left corner to move threw the numbers than use the bottem right butten to change it
Mar 28, 2010 | Casio F91W-1 Wrist Watch
Everytime i press the arrow button to go to the main screen the mp3 shuts down but freezes while in the process. how do i fix this.
Update the firmware
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 11, 2009 | Philips GOGEAR SA6045 MP3 Player
Sylvania mp3 model smpk8854
when you turn it on, press the the butten in the bottem right corner. and then press the butten with the little computer monitor and the rench in front of it. press the first butten and then press english.
for any other problem email at rowe20@gmail.com.
Dec 16, 2008 | Audio Players & Recorders
It hangs on the first screen!
when i plug it in to charge it just stays on the philips welcome screen and just stayz like that wen i reset it does the same thing
Sep 10, 2008 | Philips GoGear Flash MP3 Player
Renault laguna alize radio
there is a wheel on your steering volume control.if your code is ,say 1234,turn the wheel down 1,untill 1 appears on the dash.under the wheel on the bottem is a butten,press once.the number on dash,should say 1 and the second number should flash.turn wheel again for second number,press button under nieth.3 and 4 the same way.ON THE FORTH NUMBER,HOLD THE BUTTEN UNDERNEITH UNTILL IT BLEEPS,RADIO SHOULD NOW BE ON MEGANES CLIO,R THE SAME , GOOD LUCK. STE A SCOUSER
Aug 08, 2008 | 2000 Renault 181
Reset
Please through your phillips go gear to dust bin
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
Philips HDD1630 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
