Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 plus series spin dry is not working
I have a Kenmore 90 plus series washer that is not spin drying the cloths. I hear the motor going i think. The water is draining out, but not getting the excess water out of the cloths before they go to the dryer.
The wash cycles are working.
There is a part between the moter and something else and i can turn it by hand when I lay it over on its side.
Kenmore # 110.20972993. Lid switch checks out fine. Spin cycle/pump out only works when I rotate the timer dial VERY slowly by hand to one particular position under permanent press cycle in pause/cool down. Agitates fine and will pump out when timer dial in just the right spot. No rubber under the machine so doubt gearbox issues. Me thinks it's the timer switch? Is there a way to bypass the timer so the machine will spin until new part arrives?
  • 39 Answers
Hi RoyDMAvoy
If you machine is a direct drive it could be the coulper between the motor and the transmisson is going . that is where i would start and its the cheapest too. What happens is the black rubber pice streches, so the motor cant put full tork on the trans so it wont spin fast and take the excess water out.
brent
Posted on Sep 30, 2008
  • 13,433 Answers
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
    Genius:
  • 3,422 Answers
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Kenmore 90 series that i have to run through drying cycle twice before the clothes get dry"
try washing the lint screen it gets blocked if you are using fabric sheets
Apr 28, 2009 | Washing Machines
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Kenmore 90 series washer will only spin with a couple of pieces of clothing in it, when I add more wet clothing it will not spin. If I take some cloths out it will then spin. When washer spins the water is...
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Nov 12, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 90 series
you can look at the water pump inlet and outlet hoses. sometimes socks and other small items would be sucked in and blocked the water from going out.
another theory would be the clutch on the spin cycle is slipping that is why the drum is not spinning as fast as it should.
tnx 4 using fixya,
drcool
Sep 02, 2008 | Kenmore 15864/15862 Top Load Washer
In resposnse to guest Dec 29th - I read further and later tested the lid switch. That did the trick. Thank you for the information contained on this site: not only did it save me a service call, but my wife was ready to purchase a new unit. Thanks to all those that have contributed in the past, your knowledge is invaluable to the do it yourselfer. C.F.
Aug 09, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
251 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
