Question about Mitsubishi WT-46807 46" Rear Projection Television
MITSUBISHI WT 46807
When I turn it on, the screen it will be on for a couple hours than it just goes black, and I can't turn it off sometimes by pushing the power button.
  • Mitsubishi Master
  • 5,568 Answers
You have a power supply decaying; it will likely get worse. There may be board repair of this available so locate the power supply board - look at the assembly that seems closest to the AC cord, check the board number and search on it.
NOTE: There may be more than one number on the board since the bare board may have its own but it will be obviously a part of the board. The assembled board number will look much more temporary and may even be on a label.
If you locate a service company that claims the ability to service it, pick their brains a little since it may not be a main power supply failure but rather another, possibly separate board that produces the high voltage for the CRTs. If you do find a separate board that seems to be servicing the CRTs, note that board number too and ask them about both.
Posted on Sep 30, 2008
Audio but no picture mitsubishi wt-46807
Did you try the OPTION menu---think I offered that to you a few days ago......
Mar 27, 2012 | Mitsubishi WT-46807 46" Rear Projection...
My Mitsubishi WT 46807 will not power up. The green light on the front stays on for approximately 2 seconds and then goes out with no audio or visual. I tried unplugging the set for about 15 minutes but...
yes!
When you turn set on and power light goes out do the self check this set has.
On front of set when light goes out press and hold both the Menu and Input (device) buttons at the same time and hold both for at least five seconds and then release both.
Power light will blink a two digit error code like 2 blinks,2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means. Make a comment here and I will assist you.
SD TECH
Nov 27, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Does the Mitsubishi WT-46807 need a converter box to receive a HD signal?
Yes, this model only has one HD input--it is the one marked on the back of the set as DTV---you need to hook a box for HD to that input.
SD TECH
Oct 23, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsub tv
can you be more specific ? i don't understand your posting. what is the problem with your tv?
Nov 22, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Help me WT-46807
dear friend i have a question for you. do you get sound?
if you do you may have some bad caps or there is a 5volts regulator that goes bad sometimes and you get no picture.
lets start with this...
Oct 01, 2008 | Mitsubishi WT-46807 46" Rear Projection...
WT-46807 HD PRoblems
GO TO INPUTS ON THE MITSUBISHI AND TURN THEM ON, THEY COME IN THE OFF POSITION
Nov 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Burnout ? wt-46807
There could be a Pip problem or the vertical sweep could have went out also so then the set shuts down the video so it does not burn a line across the tubes. Theres really no way to tell what is wrong or it would just be a guess, a shot in the dark. Call out an authorized repair depot and get an estimate. Good Luck
Oct 29, 2006 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
