Question about Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player
Adjusting audio how do i adjust my audio without a remote
If you are wanting to adjust the bass and trebble etc. just push in the left joy stick and either push it right and left for the selections and turn it up and down to change or use the touchscreen function to adjust
Posted on Oct 10, 2008
I have Kenwood 106vr receiver, still working but lost remote control. Is there other way to adjust the BASS & TREBLE directly in the unit?
Hello
Not possible to adjust the tone without the remote.
if you have the possibility for a universal remote like "Logitech" remotes its Recommended for such cases, that will be easier for you to control the the AVR system.
Jun 13, 2016 | Kenwood Audio Players & Recorders
Tip
Service menu codes mitsubishi
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
# Using the remote control press:
{MENU} {0} {3} {5} {3} buttons.
{MENU} {0} {3} {5} {7} buttons.
# Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
# {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
# Press the {ENTER} button to save the change.
# Press the {MENU} button twice to exit service menu.
{MENU} {1} {2} {5} {7} buttons.
{MENU} {1} {2} {5} {9} buttons.
{MENU} {1} {3} {7} {0} buttons.
{MENU} {2} {3} {5} {6} buttons.
{MENU} {2} {3} {5} {7} buttons.
{MENU} {2} {3} {5} {8} buttons.
{MENU} {2} {3} {5} {9} buttons.
* Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
* {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
* Press the {ENTER} button to save the change.
* Press the {MENU} button twice to exit service menu.
{MENU} {8} {2} {5} {7} buttons.
Mits VZ8 chassis Menus
Option menu, Menu 1270
Service Menu, Menu 1257
Convergence Menu, Menu 1259, 4 Fine,
5 Coarse, 6 Misc.
on Apr 29, 2015 | Mitsubishi Televison & Video
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
How do I adjust the surround sound without the remote?
I was able to find a manual for this receiver at this URL...
http://www.devicemanuals.com/productsupport/Denon_AVR-800_manual.html
Its a free download. I did a search through the file and there is a way to do this. Apparently, the remote for the AVR800 doesn't allow you to adjust the rear speakers anyway, so no problem about no remote.
Hope this helps...post an update if it does or not and I'll keep searching for an answer if not.
Feb 01, 2013 | Audio Players & Recorders
Adjust speakers without remote
usually you can cycle though the settings on the front of your amp, using the jog dial. If not possible contact company for replacement remote. But I can do everything on the front of my receiver. By the number of buttond on this model you should be able to.
Dec 09, 2012 | Pioneer VSX-D606S Receiver
Can i get a universal remote?
You can get a universal remote designed to work with home theater and other home stereo equipment.
Jun 06, 2012 | Denon AVR-4800 Receiver
Can I adjust the level of each channel from the receiver, not from the remote control (the level button on mine is not working)?
Depends on the reciever, some due and don't, my advice is to get a universal remote that will work with your reciever and then you can adjust your settings no problem. I own a Yamaha RX-V3800n and you can hardly do anything without the remote.
Hope this helps
Sep 24, 2009 | Panasonic SA-HE7 Receiver
Rockford fosgate amp 5 ch
most likely your remote wire or remote crapped out if not its your amp itself can you adjust and play without remote? if so go to this site for info and replacement as well as tips:
http://www.rockfordfosgate.com/rftech/wire_calculator.asp
Dec 05, 2008 | Rockford Fosgate 800.2 Car Audio Amplifier
Car Audio & Video Logo
32 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
