Question about Sony NWZ-A816 Digital Media Player
Volume not working
Sent 6 month old NWZ-816 back to Sony after volume and back buttons wouldn't work. Sony have sent back letter sating it is water damaged and not cost viable to report. They now want £34.08.
I know for a fact that it hasn't been anywhere near water and ranted on the phone to the Sony repair centre. Wanted to speak to the engineer who diagonsed the problem and after much persistance was told they are sent to Hungary for repair. Really annoyed as feel that I'm being ripped off.
Anyone else had this problem?
    President:
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
Sony walkman volume
spray 90% rubbing alcohol from a spray bottle into the volume button area push the button reapeatedly or, turn the knob back and forth then: let it dry for about an hour then try to use it the control should be clean and working again.
Dec 03, 2013 | Audio Players & Recorders
Sony walkman NWZ-E344 volume control button wont turn up! I pressing the plus button on the volume control located on the side of the mp3 player but it will do nothing but the volume low button with minus...
Possible that the volume UP button switch within the player is damaged and so it is possible that this can be rectified only if the switch contacts are in order or that the switch be replaced.
Sep 06, 2011 | Audio Players & Recorders
My volume control is not working properly. It says AVLS. What does that mean?
AVLS stands for Automatic Volume Limiter System - and it basically limits the maximum volume being output which is why your volume control isnt working properly. You will need to go into settings to turn this option off.
Press and hold the back/home button until the HOME menu appears, press the arrows to select Settings then press the Play button to confirm, press the arrows to select Common Settings then press the Play button to confirm, press the arrows to select AVLS(Volume Limit) then press Play button to change it to OFF.
Jan 27, 2011 | Sony Walkman NWZ-B135 MP3 Player
The volume-up control is not working.
Here is a copy of your owners manual
http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/warranty/SEL-asset-166073.pdf
These units are very popular for having install errors, volume problems, recording issues etc. You need to install its driver to get it recognized by system,did you get a cd or mini cd with it?If the unit was accidently dropped, the volume will be affected without you even knowing it. I've seen these broken in parts and put back together with lots of solder work. I recommend getting a fresh set of batteries, checking the data transfer cord, power cable for any errors, and understand the at times, the volume will increase but no decrease and vise versa. This has a lot to do with wear and tear on the buttons and again, accidently dropping the unit.
Jan 12, 2011 | Sony Walkman NWZ-E344 Digital Media Player
I have a walkman nwz-e345. Recently the volume has stopped working. I can turn the volume down all I want, but not up. When I reset it, the volume returns to a volume around 10 or 15. What can I do to get...
i have the same exact problem. the volume down button works ok. the volume up button seems to do any of a number of different functions other than turning the volume up again. it has just gotten worse and worse. christ damn i hope someone can figure out a fix.
Oct 19, 2010 | Sony NWZE345 MP3 Player
W902 Sony Ericsson. My Walkman button and my volume up wont work properly.. i'we already opened up the phone and cant seem to find any damage or visible faulties on the buttons. They seem unharmed and they...
Seems like a known issue with the W902. Same here, dropped my w902 a few months back and the Walkman button and Volume up keys not workin now.
Walkman button not really an issue as you still can navigate to it via the menu system but no volume UP key is annoying. You can't increase volume especially when you volume it down. Power the w902 down and up, will reset volume to 6/10.
Solution: I came across a site where you can change volume without the volume up key.
1. Ensure you lock the phone (* and Contact key)
2. While holding down the disconnect button (the one that you switch the phone off) and camera button (on the right side, bottom button), pressing 7 will decrease volume while * key will increase volume.
You need to hold both button for 7 and * to work. Works great for me as I dont have to replace my phone, hope this help.
Ronnie
Sep 21, 2010 | Sony Ericsson Walkman W902i Cell Phone
I have a NWZ-5616F 4 gig Sony Walkman. Unfortunately, I dropped it into the snow! I tried drying it off as best I could, and it worked for me after. Now it is working, but I cannot get any volume. I...
It sounds like the volume button got wet and now the contacts inside are corroded enough that they dont make contact anymore.. can you remove the 2 screws under the little sticker on the back and open it up? - If so and you can clean them that sounds like the problem.
Dec 21, 2008 | Sony Walkman NWZ-S616F MP3 Player
Sony rx70 3 cd changer
I also have exactly the same problem with the volume control. I was hoping to resolve the problem by doing some internal cleaning but seems like johanknopper tried it before.
I was thinking of buying a remote control separately as I lost mine in relocations. Found a second hand on-line but I am not sure if they all have the same frequency and if it works with mine.
Any Ideas?
Aug 24, 2008 | Sony MHC-RX70 Shelf System
Sony NWZ-A816 Digital Media Player Logo
55 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
