Question about Dell Dimension 8100 PC Desktop
Accessing RAM sticks in a Dell dimension 8100 tower
I can open the case, but the RAM sticks are located behind much of the hardware inside the tower. How do I get to the sticks? does the other panel come pff somehow?
  • Dell Master
  • 1,183 Answers
The following link would give you product manual . This would help you to replace the memory.
You donot have to remove the otherside. You might need to remove the PCI cards, to gain access to the memory.
Posted on Oct 02, 2008
I can't close tower cover
When your computer appears to slow down, one way to help increase its speed is by adding memory. You can easily purchase memory chips from various online sources or if you have a Dell Dimension and want to stick with Dell products, you can purchase additional memory chips from Dell itself. It is not difficult for a non computer person to add memory to a Dell Dimension, although sometimes, it is cheaper to purchase a new computer and then install additional memory.
Shut down your computer, turn the computer off and unplug it. Open your computer case. There will be two thumbscrews on the back of the Dell Dimension computer case that will release the cover. The side of the computer case will then slide backward and lift away from the rest of the box. Locate the slots for RAM. These are short off-white slots that are near the power supply on the motherboard. They will be slightly longer than the RAM you are about to add. There will be at least one RAM chip already in place in one of the slots. Place your new RAM chip into a blank slot gently. It does not matter which slot you use; any will work. When you press the RAM into place, be sure the notch on the chip lines up with the slot. There will be a guide on the slot to ensure that you do not insert the chip backwards. Press down on the RAM chip until it locks into place. There are two guides on the side of the slot that will snap into place on the sides of the chip to ensure the chip does not fall out. It will take a bit of pressure to make the chip snap into place, so press straight down into the motherboard to get the chip in place. Close the computer case, put the thumbscrews back where they belong and start up the computer. Your Dell Dimension will sense the new RAM, which will be available to the operating system when the computer starts up. Hope this helps.
Dec 30, 2012 | Dell Dimension 4600 PC Desktop
What does 3 long beeps then continuously shorts beeps mean? It will just show this message own the monitor: "RV370 P/N 113-A62801-106 BIOS.
The video card has failed and you will have to replace it. Your pc has a PCI Express x16 card slot so every new card will be accepted - get the most expensive one you can afford.
May 26, 2011 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Can a dell dimension 2400 have 2 GB of memory, right now I have 1 GB
Please open up your pc and make sure the RAM card is inserted correctly, if it is inserted correctly, it is probably that the Ram has gone faulty and you will need to replace it, but they are so cheap.
Hope this helps
Mar 23, 2011 | Dell Dimension 2400 PC Desktop
Can I install one (1-gig) memory stick instead of 2 match pairs (only have one) this is to replace two 256 sticks?will it preform at 1 - gig memory
The Maximum Total Amount of Ram Memory is 2GB.
The Maximum Amount for EACH ram slot is 1GB.
Ram should be installed in Slot 1, when using just one stick of ram.
This is the ram slot closest to the Processor.
The Processor reads ram memory that is installed in Slot 1, first.
This is Dell Support, and the main support page for the Dimension 3000 desktop computer,
In the list left-click on - Technical Overview
Now click on - System Board Components
Number 1 is Slot 1.
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate computer hardware components inside a computer.
Work on a table.
After you have opened the computer case, and BEFORE you remove that ram module from it's anti-static protective bag, TOUCH the metal frame of the open computer case. (Power unplugged from computer)
This will relieve your body of static.
Ignore the above if you are already aware.
May 21, 2010 | Dell Dimension 3000 PC Desktop
Help to upgrade memory of Dell Dimension 8100
Im sure you mean 1GB of ram.
Upgrading ram is possibly the easiest upgrade to a pc.Firstly shut down the computer and remove the wall plug.
Remove the casing
Make sure you touch something metal away from the case before entering the chassis of the computer... anti static wristbands are good.
As soon as you open the case you will see the dimm slots where the ram goes.
You will find two plastic clips on each ram module, just pull these back to release the ram and insert the new ram.You may need to push firmly down to lock them in.The clips will auto lock.
Just be careful not to push to hard as to damage the mainboard.
Nov 11, 2009 | Dell Computers & Internet
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
Removing outer casing of tower ?
remove outer case of ur cpu white cable will there inside place ur dvd in the top of the cpu connecvt the cables
Jan 30, 2009 | Dell Dimension 1100 PC Desktop
Dimension 4500
ALMOST ALL OF THEM .contact dell support here...
Nov 09, 2008 | Dell (KN900) ATX Mid-Tower Case
RAM sticks
Hi Runninthe8,
Please go to my site and call the number there I'll answer and I can help you much more. If we proceed anyway we would have to call because you will need to turn off your PC when upgrading or adding RAM into your computer.
Look forward to speaking with you, Cameron Bradford
Sep 30, 2008 | Dell Dimension 8100 PC Desktop
Dell Dimension 8100 PC Desktop Logo
223 people viewed this question
Alun Cox
