Fixing temperature control startup error
Temperature of the Fixing Assembly did not reach the specified temperature within the specified period of time.
Remedy1. Check connectors on the fixing film unit. 2. Replace the fixing film unit. 3. Replace the engine controller PCB.
for more help visit CBR Tech Solutions
SOURCE: Fixing unit error. Turn off and
The problem is in your fixing unit
the reasons may be
(i)The thermistor has an open circuit or a short circuit.
(ii) he heater has an open circuit.The thermal fuse has blown.
(iii)The power supply PCB has a fault.
(iv)The engine controller PCB has a fault.
Check the following,
- Check the connector of the fixing film unit.If found no problems,
-Replace the fixing film unit.Not solved?
- Replace the power supply PCB.Still having problem?
- Replace the engine controller PCB.
and that's it
SOURCE: Laser scanner unit error. Turn off
Your laser unit is faulty. Its more cost-effective to buy new printer. Having it repaired will cost about same as a new one. If still under warranty then just return and have it replaced.
Regards,
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
