Question about Bush 5693D 24" TV
Bush 32" TV. desperate situation. T-T
Hi, there.
Yesterday, i was watching TV, then, all of sudden,
the TV screen has gone, just like 'blank'.
My place is poor signal area, so sometimes, the TV lost its signal but,
there's no significant problem.
There's main power (red light) on and keeps blinking.
Normally, it was just on, not blinking.
So, i've even changed batteries of remote control.
But TV doesn't respond at all.
the red light on, continously blinking, no respond.
it's just 9months old one. T-T
Please, help me. Give me a solution for this problem.
I and my poor TV will be waiting your precious answer.!!
Thanks a lot.
Sun.
  • federica Jan 23, 2009
    I have your same problem. Mine is an LCD 27 inch with Freeview, I bought from Argos when I lived in UK and I bought also 3 year Breakdown coverage which will expire next June, but as I lately moved to another country the insurance agency told me that I am not covered.
    To add insult to injury in my country there is no Bush agent and I cannot find anyone to repair it for me, not even the parts are available here. Pls help me
  • 4,234 Answers
The TV is in protection mode. An internal problem was detected and the set shutdown to prevent further damage. If the set is only 9 months old, it should still be under warranty. Call and request warranty service.
Dan
Posted on Oct 01, 2008
Some time ago, I was watching TV, then, all of sudden, the TV screen has gone, just like 'blank'. The main power (red light) keeps on blinking. Normally, it is just on, not blinking. TV doesn't respond at...
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 24, 2013 | Bush 5693D 24" TV
My hannspree tv screen goes black blank
If the picture shows a picture briefly upon power up then goes off after a few seconds, you have a back light fault. It could have a problem in the 24vdc circuit, failing back light inverter board, or a blown CCFL lamp.
Dec 05, 2012 | Televison & Video
Black screen on VOJ32o1A
Check and replace the back light inverter board. Check CCFL lamps too.
Jul 29, 2012 | Vizio VOJ320F1A 32 in. LCD TV
Bush tv
What is the exact model number to your Bush TV?
Apr 24, 2012 | Televison & Video
I have a bush rf6685 vpl - 28" screen? - all of a sudden the colour has gone funny ie watching football the grass looks purple.
good day maybe your tv has a defect, or loose connection in the main board, needs to resolder the main board. only the qualified technician can do this job. to fix your problem.
Jun 21, 2010 | Televison & Video
Bush 32" LCD 1080p tv
Is this the BUSH "LCD32F1080P" ?
Bort from Argos for £330 (then £370 now £300)
Cos I noticed mine doin that aswell, I thrt it mite be cos im using an old ASDA HDMI cable... but now i saw your post.
Nov 05, 2009 | Televison & Video
BUSH LCD 27 inch
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 23, 2009 | Bush 5693D 24" TV
Dush TV 28" RF6683VPL switch off while I was waching tv
Hi there sorry but this could any number of things. But i dont think you could repair it your self. It would need to go to a repair shop. It is most likly a power supply fault inside the tv . All the best Bob
Jul 20, 2008 | Bush 5693D 24" TV
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
Bush 5693D 24" TV Logo
459 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
