Question about Gateway FPD2275W LCD Monitor
Daewoo Moniter blank screen
The moniter will not come up. the green power light indicater is blinking. I can not any of the functions on the front of the unit to do anything. In other words I have a totally blank screen
  • 1,879 Answers
Try connecting the monitor on another computer, swap monitor cable IF possible.
Even without any source connected to it, the power light indicator should stay solid green & depends on the make and model, should show a diagnostic or information on the screen.
Posted on Sep 30, 2008
  • Gateway Master
  • 6,487 Answers
Check the user manual for some troubleshooting steps that you can try this is the link for it http://support.gateway.com/s/Manuals/Monitors/8512088.pdf
Just go to page 24 for the troubleshooting steps ....
Hope that helps..........
    Genius:
  • 3,422 Answers
First make sure that all the cords are connected properly from the back of the CPU to your Monitor.I suggest you to unplug all the cords of the CPU and then plug them back in after 10min. and make sure they are all connected tightly.Next check if the power cord connected to the Monitor is attached tightly.
If you still face the problem then you will have to replace it with a new power cord whih connects the CPU to your Monitor.It is black in colour.
  • Priya darshan Sep 30, 2008
    If you need anymore help let me know.
Moniter power light blinks purple.
Inspect the power supply and also try it on another PC too.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 30, 2010 | Smart Modular SV3170A
My computer often fails to start. even if the hard disk is running my moniter and keyboard doesn't show ant sign of power signal and the moniter screen just remain blank with power led of moniter blinking
Note: make sure that the computer is turned off before removing the RAM from the DIMM slot. Hope this helps.
Sep 27, 2009 | MSI 845 PRO Motherboard
No picture on screen but power light blinks
May be the problem with your Pc. If you can hear a beep sound when booting the Pc is Ok. Otherwise check memmory for loose connection.
May 03, 2009 | Computers & Internet
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
My computer screen is blank on computer. have logitech ex110
Did you try moving your mouse? After a period of time of inactivity the computer will go in standby mode which can be a black screen.
Sep 28, 2017 | Logitech EX110 Mouse
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Moniter won't turn on
SOUNDS LIKE POWER SUPPLY IS OUT OR POWER RELAY IS Bad.
Probably cheaper to replace this mointor with a new lcd which uses 50% less current.
even if you find the parts to fix it i suggest replacing this moinitor altogether electrical failure is a sure sign of other problems in the future.
Oct 23, 2007 | Acer AC711B 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
122 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
