Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
I've just purchased DKT-110 wireless G starter kit.
I told the shop assistant I required a wireless router for my laptop to enable me to disconnect my laptop from my modem and let me to use it from other rooms in my home. I have internet at home with Virgin. My laptop is connected to a virgin socket at home (not wireless). I've inserted the set up disk and on-screen instructions tell me to connect the DKT-110 wireless G starter kit to my computer (laptop). This does not make sense to me. Logic tells me that device should be connected to my modem and the DWA 111 device to my laptop to receive a wireless signal from the router. Sorry if this is difficult for you to understand but I'm not a technical person and don't really know much about this kind of stuff. Any help would be much appreciated. johnhawick1873@hotmail.co.uk or 07838843929 anytime.
Thanks
John
I need to find set instruction in english
Posted on May 13, 2009
  • D-Link Master
  • 4,338 Answers
The Internet/WAN port on the router should be connected to your cable modem's internet port.
Then on your laptop, you should click on "View available wirless networks", your Router should show up there. click connect and you should be able to surf.
Note::The USB DWA 111 should be connected to your laptop and the drivers installed
Please remember to rate all users who assist you for free :)
Posted on Oct 01, 2008
  • JDTec
    JDTec Oct 03, 2008
    Did this solution help? Can I be of further assistance?
    P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved.
    • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
    • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
    • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
    • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
How much to buy one
USB Kit DIR-300 Broadband Router & DWA-110 USB Adapter DKT-USBG - D-LINK WIRELESS G ROUTER & USB KIT $94
D-Link DIR-300 Wireless G 54MBPS Broadband Router, with 4-Port 10/100MBPS Swich $63
Oct 25, 2010 | D-Link DIR-300 Wireless Router
I have a dlink dkt-110 and have no idea how to secure it without loosing it
Are you trying to secure the wireless network then you will need to access the router setup.
Is there any computer connected to the router?
If not then you will need to connect the computer to the router.
once you open to the router setup, you will see the option of secure the network.
Click here for more info
Dec 03, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
I only got my DKT-810 ALL-IN-ONE ADL2+STARTER KIT 2DAY THE CD WILL NOT RUN IN DRIVER AT ALL SO I CANT DOWNLOAD IS THERE ANOTHER WAY I CAN DOWNLOAD SOFTWARE SO IT WILL WORK.
You don't need the CD nor software to setup the router. It can work without the disc. Simply hook it up do a power cycle. Make sure the physical connection is correct.
Jun 29, 2009 | Gateway Wireless-B Router (wbr-100)
I want to purchase crickets wireless broadband to use with my laptop and i need to route my home computer to use it also. i have a dell b 110 with intel pro 100 ve. what else do i need to purchase to use...
Any wireless router should do just fine. Make sure to purchase a Wireless G or N, should be clearly stated on the box before purchase. They run about $40 for a ok one. Very easy to configure to.
Good luck with everything and I hope I could be of some help.
Jan 15, 2009 | IBM Intel PRO 19K5710 Network Adapter
Belkin router with a laptop
1. First you need to configure your router with your laptop wired or physically connected to it.
2. Connect your modem to router's WAN/Internet port. Then your laptop will be connected to the one of the router's Ethernet port using an RJ45 or Ethernet cable.
3. You may run the setup cd that came with the router. Configure it with the Internet connection type that Bell Sympatico requires.
4. The setup cd will also require you to set up wireless in the router. Once it is done, disconnect your computer from the router.
5. Enable wifi in your laptop and select the wireless network that you set up and connect to it.
Nov 08, 2008 | Computers & Internet
D LINK DKT-110 ROUTER
hi  have u tried connecting with the ethernet and have checked hows ur connection stablity,if ur r in wireless keep the wireless channel to 7,9,11 and same go to the wireless adapter properties in the device manager and check if is the same channel as the router always keep the router in a wooden table or above the ground level  have checked what domain u have conected the router . tried resetting the router to the factory settings  re configuring the router with if ur isp has different domains as all the is has more that one domain to connect,  try changing the micro filter if all the above is checked even if still the connection drops then contact the ur isp and raise a trouble ticket as it has to be delt from ur isp network
Nov 01, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless router g- starter kit
Could you elaborate a little more??
Jun 14, 2008 | D-Link Computers & Internet
D-link router DKT-710 Wireless G ADSL2+ starter kit
Took it back to shop and changed it for another one. thanks, norman3.
Mar 02, 2008 | Computers & Internet
Trying to install wireless g starter kit DKT-110 using cd rom. keeps telling me internet cable not connected when it is.
You may have more than one connection. like a 1394 connection.
Look in network settings for multiple connections.
Jan 25, 2008 | Computers & Internet
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
226 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
