Question about Philips Televison & Video
I have a Phillips 32PF531D/10 TV. I tried to reset factory settings on tv by following instructions in manual. This didn't work and now when I turn on the the TV it goes blue and 'DTV' appears on top left screen and screen then goes blank. I cannot get picture at all! Can anyone help? Thanks ED
  • 1284 Answers
SOURCE: 57 inch sony kp57wv700
Sounds like bad CRT's
Posted on Feb 23, 2007
  • 8617 Answers
SOURCE: Phillips DPTV335 colors out of alignment
you need 2 Convergence ICs STK392-120 you can get them at this link and they provide free step by step instructions with free tech support so you can do the repairs yourself.
Posted on Apr 05, 2008
  • 8617 Answers
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Posted on Jun 15, 2008
  • 927 Answers
SOURCE: mitsubishi ws65613 no picture or sound, blue screen only
Good day, Bgchzy;
This model is known for the tubes leaking fluid, glucose, on the PCB. Check the front of the chassis for said fluid, it may be only a drop, so look closely.
To fix, after TV has no power, try cleaning the board with cleaner and brush, let dry. I suspect this because of multi unrelated problems.
Posted on Jul 17, 2008
  • 12 Answers
SOURCE: My TV Screen turns green or blue after 10 minutes of the tv on
You have a chip that is overheating due to heatsink coumpound being dried up. You need to find that chip and heatsink and apply new compound to both parts.
Posted on Apr 06, 2009
How do I reset the TV to factory settings.
To reset your TV using the "MENU BUTTON" follow the instructions below: Hold down the menu button on the top or side of your TV for at least 10-15 seconds. An on screen menu will appear asking you to enter the time, date and location settings
May 28, 2016 | Televison & Video
None of my inputs work on the TV, including the Ethernet connection
test with your cell phone directly then reconnect the modem last reset tv to do so in main menu
Sep 15, 2015 | Sony BRAVIA KDL-55EX710 55" LED TV...
My volume on my 50plasma tv
Try setting back to factory default
Power off tv
Unplug power cord to wall
wait approx 10 minutes
Plug cord back in
power on tv main menu will appear follow on on-screen instructions to reprogram.
Apr 13, 2013 | Panasonic Tc-p50c2 50-inch 720p Plasma...
My Phillips 20PT6245/37 TV won't turn off
On and off commands come from the main board, if it won't shut off you need a new board
Feb 01, 2018 | Philips 20PT6245 TV
Why is my LCD TV not powering on after resetting to factory settings?
Kindly study the operation manual and follow instructions for installation from the beginning. You may have to switch off the TV manually, switch off power, remove plug, wait for sometime and retry this.
Jul 30, 2012 | Toshiba Televison & Video
Panasonic PV-DR2714 will not turn on and i lost the remote
Hello Bobby
You haven't given enough details about the fault to your Combo. What do you mean my 'power button has coninuity on board'. I assumes that you get power LED at the front of your device lights up when you switch ON the main power switch, and the unit refuses to power ON and work further. If so, just make a factory reset to this set as it will reset the memory IC. To reset the unit to its factory reset do the folloing. But to do this, the power LED on the front panel of the unit should light up. Otherwise, the fault will be to its power regulator section. To reset the unit to factory reset:
[1] Turn the Power ON.
[2] Hold down both PLAY/REPET and FF on the unit more than 5 seconds. The power will shut OFF. Please ignore "NO CASETTE" warning.
[3] Perform initial set up refering to its user manual. You can see instructions to initial setup at page [16] of the user manual to your device. OK.
Dec 07, 2011 | Panasonic PV-DR2714 27 in. TV/VCR/DVR...
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com, to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
Tv turns on but no picutre, no menu... and then tv proceeds to turn it's self on and off, on for 10-15 seconds and then off for 2-4 seconds and then back on.... Is there some type of manual reset button on...
Just set it to factory defaults first. Setting it to cactory defaults, will reset all the items except picture settigns. Parential password will also be get resetted. You have to set it later. To reset the TV to factory defaults, do the following.
[1] Push Menu button and select Setup.
[[2] Select Reset To Defaults from the drop down window.
[3] Push OK button.
The TV will reset to factory defaults and will display it. After that it will switch ON again. Ok
Jan 29, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
Dec 13, 2009 | Televison & Video
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
Televison & Video Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
