Question about Copystar CS-2050 All-In-One Printer
CS-2050 Fax problem
We recieve faxes normally but randomly evry 5th to 20th fax will not go through and we hear a loud rapid beeping coming from the machine. There are no error codes on the display and when you print a fax report it only says it failed no code.
They machine recieves a fax then transfers it via the network to a server storage file. The local company came out and updated the frim ware to the latest and said it must be noisy phone lines. They then admitted they didnt have a lot of experience with this.
Any thoughts?
  • 40 Answers
Check if the fax system using G3 or G2 or G1
Posted on Sep 01, 2010
Cant send or recieve fax
Might be silly question but is it setup to auto transmit and receive? And have you tried to operate it manually? + take out the inline filter fax machines operate on volume'db' to soft and it can't hear, to loud and it can distort sound.
Dec 28, 2013 | HP Office Equipment & Supplies
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
Cant get incoming fax
be sure phone cord is plugged into line port..not tel. Or your machine is in manual mode. Press button under lcd panel that says recieve mode until display reads fax/tel.
Apr 12, 2012 | Canon LaserClass 2050 Plain Paper Fax
Canon Fax L100 has Comm Error. Seems to re-appear often. Presently not recieving faxes. Please help!
evry time press red button to clear it. It means that there are interferences in send or recive. Check your tel. lines.
Oct 09, 2009 | Canon FAX-L100 Plain Paper Laser Fax
I have a 2050P fax and it has not been receiving faxes for a week. Is could it just be programmed incorrectly?
Make sure the phone line is plugged in correctly...ie. into LINE not PHONE. Facsimile machines will recieve , normally, without "programming" for sending number or company name. You can also check to see if the line is active by pressing the on hook button for a dial tone.
Jul 20, 2009 | Canon LaserClass 2050 Plain Paper Fax
Will recieve fax but wont send a fax
sending fax is free, however you have to have a dedicated fax line with your phone company to recieve.
Jun 27, 2009 | Kyocera Mita KM-2050 Printer
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Recieveing
If all else fails try the manual mode:(Press Receive Mode to select
FAX ONLY, FAX/TEL,TAD:ANSWER MACH. orMANUAL.)
Manual Reception
Pick up the handset while the phone is ringing.
2 Press Fax Start if you hear fax tones (beeps).
3 When the LCD shows RECEIVING, replace the handset.
(best used when you are expecting a fax and know that the incoming call is a fax)
If you are like most people you probably also have a phone with an answering machine or voicemail setup on your home phone. If this is the case you may want to set the reception made to
TAD:ANSWER MACH.
May 28, 2008 | Brother IntelliFAX 2800 Laser Fax
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Copystar CS-2050 All-In-One Printer Logo
103 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
