LG 19ls4D monitor/TV Why wont it work with my pc above 640 by 480. if i try and set above this with lowest picture quality aswell i might add. it just says 'no signal'. im uusing XP service pack 2 with an agp X8 X1650XT 256mb graphics card? no matter what i do it wont work there are no drivers as is supposedly a plug and play monitor. its fine as a tv but i dont want it as a tv!
  • Jozefos Sep 30, 2008
    Also just to advise aswell to even get it to work like hat i have to press F8 on booting it up and chose enable VGA mode!
5 Suggested Answers
Open SKy
  • 604 Answers
SOURCE: WOW and Radeon x600
Filrup
Happy Holidays
Well, WOW can be fix, but I suggest, that you uninstall ALL video drivers on device manager FROM SAVE MODE. then startup your PC on normal mode, it will tell that install the video drivers, at this point, disable your Antivirus, and Install ONLY the version (original) that came with your video card. Then fire up the WOW. it SHOULD fix the problem.
Posted on Dec 10, 2007
  • 13433 Answers
SOURCE: Re:XP Screen resolution settings
from this website
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&trac=SU1
Posted on Apr 07, 2008
  • 359 Answers
SOURCE: lg w2242t lcd screen is
According to your manual, the recommended resolution for this monitor is 1680 x 1050 @ 60 hz. Is this the display setting you are using? Manual is at http://www.lge.com/products/mobile/cdma_manulist_gcsc.jsp.
You should be able to use the driver supplied by the manufacturer, and it should not cause problems! If you are in the U.S., support contact info is at http://www.lge.com/support/gcscWrite.jsp, and includes phone number. Given that this monitor is new, I would suggest telephoning LG for support, and if it is not resolved sufficiently, returning the monitor. This monitor should run perfectly with the supplied driver, and if not, there is a hardware malfunction or conflict. LG should be able to tell you definitively if there is a way to solve the problem, and if not, suggest that you return and replace it.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 02, 2008
SOURCE: Connecting an LG TV to my PC
switch to any setting as long as it is only in 60hz and nothing above that the monitor cant handle it
Posted on Sep 11, 2008
  • 11 Answers
SOURCE: Dell C521 Where to connect monitor?
This means that you have an external video card (which is not outside the computer). This video card will be plugged into the motherboard. That message is saying that the port on the back of the computer that your monitor is plugged into is the wrong one. You need to look for another port on the back of the computer.
Here is a picture of a VGA port that you should use if you have a VGA cable to connect the monitor (Blue Ends).
http://news.softpedia.com/images/reviews/large/VGA.jpg
Here is a picture of a DVI port that you should use if you have a DVI cable to connect the monitor (White Ends).
http://zedomax.com/blog/wp-content/uploads/2008/09/dvi.jpg
So depending on the cable and connections that are available on your computer and your monitor depends on what you have to use. I hope that wasn't too confusing. Let me know if you need more info.
Posted on Feb 12, 2009
Blinking with no signal video displayed,also blinking picture after started windows
"no signal" means exactly that. You monitor is not receiving signal from your PC. Recheck the video cable on both the monitor and the PC, make sure they plugged in properly.. Also try another monitor if you have it, and if it works with that monitor than more likely you have a frequency sync problem. In this case, using another monitor that works, and try resetting the video to basic 60Hz. In Windows, Start->Control_Panel->Display. Change the display resolution to the lowest, apply the setting, then change the monitor back to the questionable one. If it still doesn't work, then your video processor on your monitor is bad; RMA it if it's still warrantied.
Blinking picture problem, try suggestion above.
May 30, 2010 | ViewSonic VX1935wm LCD Monitor
No picture on TV with Dell Inspiron 6000
the problem is your video configuration its supposed to be Tv-in on computer so you can receive video on the laptop screen
Jan 25, 2010 | Dell Inspiron 6000 Notebook
Monitor will not light up, laptop works fine using external monitor
The screen could be cracked or broken altogether from pixel damage. If so, there's not much you can do to fix it. Check your settings and put them at the lowest resolution and lowest quality settings while connected to an external monitor. Good Luck!
Jan 05, 2010 | Toshiba Satellite L305-S5933 Notebook
Powers itself off after 5 sec.
Hi there , please try this screen on a diferent PC aswell , it helps to distinguish the problem , if its the PC or SCreen , if it does the same , try changing your power Saving Settings aswell...that should work, Other then that it could be a faulty Screen.
Thanks
Dec 29, 2009 | Sylvania SSC192 19 Inch Tv/vcr Combo...
CanĀ“t connect my laptop to tv monitor
Try lowering your screen resolution on the laptop first. (Right click on desktop > properties > settings tab > and move the bar to the left - try the lowest setting to start with
Jan 22, 2009 | Acer Aspire 4720 Notebook
Medion monitor shows analog out of range and will not turn on
Two options here. 1) Boot into safe mode, open control panel, display, settings, change the screen resolution to the lowest setting and color quality to their lowest setting and reboot. If that works move your setting up to where you used to have it (i.e. 800x600 pixels. Another option is to use System Restore to restore your system to an earlier date...a program you recently installed could be the culprit. System Restore is located at Start, All Programs, Accessories, System Tools.
Jan 14, 2009 | LG Flatron L1750S 17" LCD Monitor
The tv code for model 19LS4D so i can use my sky remote rev 6
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 23, 2008 | LG 19LG30 19 in. LCD HDTV
I am connecting a Technika 1031 to a LG 19LS4D using a good quality scart. I get sound but no picture. Connecting via the Y, Pb/Cb and Pr/Cr ports does nothing. Am I doing something wrong?
Make sure that the proper input is selected on the TV. Also, check to be sure that the correct output is activated on the DVD. I'm not familiar with the Technika brand so verify the output selection in the owner's manual.
If those selections are correct, try connecting to the standard AV input using the Red/White/Yel cable connection.
Dan
Mar 18, 2008 | Televison & Video
dear sir
i think u have screen resolution pro.
change your system resolution to 800x600 .reso.then restart .
i think your problem is solved
Mar 16, 2008 | Computers & Internet
Connecting to PC
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Apr 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
Computers & Internet Logo
167 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
