SOURCE: 1993 ford tempo doors wont open or unlock
It's internal. Whatever the problem is, it's gonna require you to take the door panel off and examine. I suspect worn bushings and/or bent linkage. Someone may have tried to "jimmy" your door open with a slim jim and messed something up.
SOURCE: 2005 dadge dakota tailgate wont open
You can access it from the inside of the tail gate,there is a plate directly on the other side of the handle,Just take that plate off and reattach the rod mount or replace the handle if it's broken.
Here are some pix
Please rate this a fixya
SOURCE: Left Passenger Door Wont Open 89 subaru Wagon gl
Pop the door panel and look for one of the rods from the inside door pull that is disconnected from the latch. The little plastic rod holder 'gizmatchi' is probably broken - dealer or junk yard part.
SOURCE: rear doors will not open from either side in
the only thing that could have happened is the child safety locks are on. that is why you can not open them from the inside and the outer handles have broken . the thing to do now is to use a tool called a slim jim to open the doors . then unlock the child safety locks so you can still use the doors until outer handles are replaced.
SOURCE: my back doors wont open,
Your post is somewhat confusing, BUT with child locks engaged, you can only open the door from the outside, when unlocked.
