Question about Olympus FE-210 Digital Camera
Broken shutter I had my new camera only 3 days when it was dropped and a piece chipped off of the shutter. Now everything is white (because of all the light). Can this be fixed or should I trash it?
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
You can send to the Olympus repair. there is free estimate.
Posted on Oct 01, 2008
My camera screen is white totally no colours no menus cant see anything just a plain white screen it dropped about 13 inches any help
Have you tried pullimg yhe memory chip ad batteries and reloading them. And if camera is that new it should still be under warranty take it back to where you purchased it, dont tell them you dropped it and they should help you or replace the camera.
Aug 23, 2012 | FUJIFILM FinePix XP10 XP11 Digital Camera
HELLO , LANCE HERE (NEW ZEALAND) I HAVE A CANON POWERSHOT A430 ABOUT 3 YEARS OLD, ITS STARTED TO HAVE A PROBLEM ON OUDOOR SUNNY DAY PHOTOS, ALL THE PHOTOS COME OUT WHITE, OVER EXPOSED, SEEMS...
Probably the shutter flex cable is broken inside the lensblock,or replace the lensblock,labor extensive,technical skill required.
See other solutions for similar faults.
Jean
Jan 02, 2011 | Canon PowerShot A430 Digital Camera
It dropped, we got all the pieces but the lens has two lose springs and the lens protectors won't close or open any more
The lens mountings have come out and hence the shutters have moved out of mechanism and alignment. It will be necessary to open the camera and start to refix them. If it had fallen on the lens then there is a possibility of the the hood mounting been damaged. If so you will need to fix this out but if any plastics are broken then the alignment may not set well . The best is to approach a camera repair centre preferably Canon , and try to piece it , this will be much better than to assume the fittings. Hope you try this out. Good day
Aug 12, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My camera cant photoshoot on outdoors, everything that captured looks white. When I photo shoot in our house -- dark room, it seems fine, but WHITE HORIZONTAL LINES appear? I've already used it about 3...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, recommend trying the pencil tapping method described in this article for a stuck "open" shutter.
Jul 31, 2010 | Canon PowerShot A470 Digital Camera
I dropped my camera (powershot sx110is) its taking blank pics
lens unit shutter section failure,take out the shutter unit replace the broken part,if not take to a camera tech
Mar 07, 2010 | Canon PowerShot SX110 IS Digital Camera
CRACKED SCREEN
You cannot repair the broken LCD screen; the white you are seeing is the backlight for it. LCDs have extremely thin gold deposits along one edge that is contacted by a silicone rubber strip that has fine wires molded into it vertically and one edge is pressed against the LCD panel for contact. It is a fussy arrangement when new and it sure doesn't get any better when dropped.
I wouldn't delay too long looking for parts or repair; Polaroid filed for bankruptcy last week although I doubt if the parent had anything to do with the manufacture of your camera; as with many companies with limited manufacturing means, the camera was surely built by others.
Dec 21, 2008 | Polaroid i832 Digital Camera
Striped pictures
The sensor chip on which focused light falls has a failed connection. The image is 'read' via a matrix that is scanned to retrieve the image and one of the paths of this matrix is broken.
Oct 14, 2008 | Kodak EasyShare Z760 Digital Camera
White lines appearing across screen
Call toll free number for support.
Cheers!!!
Ujjwal B Soni
Sep 29, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Dropped camera
My camera fell out of my pocket book and busted the door. I glued it. that worked for about 6 months. I need the door for it and it will be as good as new.
Jul 21, 2008 | Polaroid i832 Digital Camera
Stuck lense on Kodak Eastshare camera.
The machanisim is broken Arepairs is not likely or will cost nearly as much as a new camera. So go for a new camera
Jan 22, 2007 | Kodak EasyShare CX6445 Digital Camera
Olympus FE-210 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
