Question about Epson Stylus Photo R220 InkJet Printer
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
This laptop has Webroot Parental Controls installed with Windows Vista Premium. The Epson Photo R220 Printer connects USB to the Linksys Print Server via USB. The laptop is connected by testing both methods, connected to wireless through the print server and linksys router N. and Ethernet or connected directly to the printer via USB. I do not know how to setup the printer for the network.
  • 1 more comment
  • Anonymous Mar 12, 2014
    how do i connect epson dx4850 to samsung chrome via usb
  • Anonymous Mar 22, 2014
    I have a new laptop with windows 8 on it. It won't find the printer, even when it's connected via usb.
    Problem Solver:
  • 14 Answers
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Posted on Oct 13, 2008
Can the epson R220 print wireless
It can't print wirelessly with the native hardware. It has a USB 1.1 connection. You may be able to find a print server that can connect to a wireless router. However, you will need to check the specifications. Some print servers will only work with select printers or OS combinations.
The specifications for the R220 are here: http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=yes&infoType=Specs&oid=58654761&category=Products .
I hope this helps.
(note since this is an older printer with a USB 1.1 connection, you can expect the printer to be slow with a wireless connection. If your signal strength drops, you may need to reboot everything (computer, print server, router and printer).)
Mar 21, 2011 | Epson Stylus Photo R220 InkJet Printer
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
I need to install an epson stylus photo R220 printer to my computer so i can print,but i dont have the software cd to install it to my computer. What do i do? How can i setup the printer to my computer so...
Hello, just google 'Epson Stylus Photo R220' and go to the Epson website where you will see a section marked 'Drivers and Support'.
You will be able to download your drivers from there.
Hope this helps!
Regards,
nicam49
Dec 22, 2010 | Epson Stylus Photo R220 InkJet Printer
Need software for Epson Stylus R220
From Epson's website:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=60202&prodoid=58654761&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=27&y=8
Aug 27, 2009 | Epson Stylus Photo R220 InkJet Printer
I need the software & drivers please 4 epson styuls photo R220 some one send it to wickedwelchtattoos@att.net thank you.
Sep 22, 2008 | Epson Stylus Photo R220 InkJet Printer
How do I get my Epson Stylus Rhoto R220 to work with windows vista
I have an Epson Stylus Rhoto R220 inkjet printer for 10 months and i would like to know if its going to work with Vista Windows PC or it won't recognize my printer. How do I upgrade it or get it compatible ?Thaks
Feb 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r220
Open the printer Properties, Under quality there should be a box
that you can check (print in greyscale) or (print in black & white).
You have to remembe to uncheck to print in color.
Feb 04, 2008 | Epson Stylus R220 Photo Printer Color...
Epson Stylus Photo R220 InkJet Printer Logo
527 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
