Question about Sony Ericsson W550i Cellular Phone
I have just got this unit from ebay which said working.The scholl down button in the centre of the phone does not function although up,left and right does.Any ideas please?
    Brigadier General:
  • 7,752 Answers
The sub key board needs replacing
Posted on Oct 05, 2008
Ford mondeo car radio code 2006 titanium x
try entering the code then press button 5 to enter the code ,then write the code on the back of the sunvisor ,them cards get lost or the dog or the baby chew them up ,
Aug 20, 2013 | Sony Car Audio & Video
Camera keeps taking pictures uncontrollably
Hmmm have you checked the interval setting...sounds like it's set for 1 pic every second.
failing that, it could be a repalcment. have a go at reseting the settings from the start.
Regards
Mr Yoda
Aug 31, 2010 | Bushnell Trophy Cam with Text LCD
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
Answer to Clarification request
no probs..here is the way,start from the default screen
press the menu(centre button of the 4 way pad)--two down presses on the 4 way pad--centre butto-- again centre button--upper left button--three presses of down button --centre button--centre button again--one click of down button--one click of down-centre button--top left button
that should move all from SIM to Phone
please get back if any help/clarification
Nov 27, 2008 | Nokia 6030 Cellular Phone
OLYMPUS STYLUS 1030SW. up, down, left, right and centre buttons not working
good day,
although it might seem a hardware problem, you might also consider the software used in sensing what buttons are being pressed.
i suggest that you have it checked by a competent technician at your nearest olympus service center or to your seller. dont forget to bring your warranty card (if it is still valid).
i hope this helps
Oct 12, 2008 | Cameras
My key pad
left softkey andv tehe right softkey button, naturally will not function, coz you need to assign shortcuts on those button, it not yet configured, so you need to customized it yourself.
Feb 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Fixing 5-way joy stick.
no way only the center button acn assign a function . other 4 keys can be only used while using menu or gaming functions u can change the application selection for center button in seetings> phone
Dec 04, 2007 | Nokia 6620
Sony Ericsson W550i Cellular Phone Logo
15 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
