Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer throwing H the F code
2 year old duet washer that started throwing F06 code-changed the main computer-didn't help-changed the panel behind the buttons on the front- now the maching throws a code of H and then F
    Genius:
  • 1,028 Answers
F06 usually means problem in motor speed circuit either main control or motor control or possible wiring connections..FH is usually a problem with the flow meter left side under top has small hose from fill valve and one to dispenser...it's not reading water flow to machine a light tap may help confirm problem if doesn't help may need to change flow meter anyway small switch on small bd with wires will stick and not signal main bd there is water flow
Posted on Oct 02, 2008
My whirlpool duet washer has error codes, F06, E01 and int. how can I reset the washer?
The Electrically Erasable Programmable Read-Only Memory (EEPROM) on the main electronic control board is corrupted. Unplug the washer for 5 minutes, restore power and see if the code clears. If not, the replace the main electronic control board.
Oct 14, 2016 | Whirlpool Washing Machines
My Whirlpool Duet is showing error codes f06 and e02 and wont unlock door or run cycle, what can I do?
Janice,
Here is a link to a website that gives the F06 code, but I cannot find the other code.
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.
Scroll down towards the bottom to find the Duet fault codes.
Jul 28, 2015 | Whirlpool WFW94HEX Duet 5.0 cu. ft. Front...
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
F06, E02
I think these problems are related to water inlet, take off the hoses from the back of washer and you will find a screen in the outlets clean with old tooth brush until clear.
Feb 19, 2014 | Whirlpool WFW95HEXW Duet 5.0 cu. ft....
Whirlpool duet front load washer, F06 error
FROM WHAT I CAN FIND OUT YOU HAVE A DRIVE MOTOR PROBLEM,
IF YOU TYPE IN YOUR SEARCH BOX (WHIRLPOOL FAULT CODE F06) there are several several sites that tell you how to fix it
Nov 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer-error F06 and E02
Unfortunately F06 E02 is a very bad error. It means you have an interface communication error. That means that the main control board isn't communicating with the front interface control board. You can pull the washer out and remove the 3 screws coming in from the back of the top panel. Next, the top panel will pull straight back, up, and off. Now check all the wire connections between the two control board and make sure they are all secure. If everything looks good, then the interface control board will need to be ordered and replaced.
Here is a link to the part.
Oct 19, 2012 | Whirlpool Duet Steam WFW9750WR Washer
My duet does not wash it keeps coming a code F06, what could it be
F06 error code is Drive Tach Motor Error.
The cause of this is the motor control (MCU) not communicating with the control board. Try unplugging the unit for 30 seconds and if this does not solve the problem replace the MCU. This is located behind the panel under the door screwed to the floor of the unit near the motor.
Click HERE to order the replacement MCU
Hope helps.
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi please help how to resolve probelm with f6 error code on whirlpool duet washer? Thanks you, Tammy
Whirlpool's 'F06' decodes as 'tachometer failure, no motor movement'.
It does sound as if the motor requires replacement unless it is the control board not powering the motor.
Now, a word or two of advice from a retired Englishman in SW France. It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the com, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor on our 19+ year-old Bosch at a cost of GBP250 ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet 2 1/2 years old I t has started to make a loud buzzing hum sound (that sounds like old top loader mixing valve malfunction?) and has error code 5d what is this ?
Actually, your error code is "Sd" and indicates that the washer thinks that there are too many suds in the basket / drum.
Your buzzing sound is also likely to be the water inlet valves, common to top loaders as well, as the washer is adding additional water to rinse excessive suds out. Check your supply hoses for kinks, connections for scale buildup inside, as well as the screens on the inlet ports of the washer itself.
A kinked or restricted drain hose can also throw an Sd error code as well.
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
216 people viewed this question
Dan Webster
Dan Webster
Sal De
