Question about GPS
Garmin c340 cannot get sat signal for more than five or ten minutes,then get low signal message befoe losing signal completely.some days no signal at all.
  • Jlchizzy Sep 30, 2008
    have lost satellite signal all together. will be out for days and then suddenly it will work for a couple to 10 minutes and then gone. nothing there at all.
    Understand updating software 3.6 will help. How do I update the software??
Had the same problem, there is a solution, Lowrance has a series of problem fixes by reseting the unit. I found it by e-mailind Lowrance and they gave me the web site. Sorry i can't remember what keys you hold, but it was simple and it worked.
Posted on Sep 30, 2008
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 loses the satellite very frequently. Battery?
1. make sure the unit is as low un the windshield as possible, remember it needs to see the sky, the more sky it can see the more sat it can lock in on.
2. Check the GPS Mode, under tools(Wrench), select system, the GPS mode, make sure it is in the normal setting. WAAS is more accurate, but most of the sats are at the equator, so in some areas the coverage is not as good.
Hope this helps.
Apr 17, 2009 | Garmin StreetPilot c340 GPS Receiver
My garmin c340 will no longer connect to satellite
Try updating at Garmin Here
This can resolve sat problems
Apr 15, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 Street Pilot
I had the same problem. Found out that the fuse had blown in the power cord. I bought a new fuse from radio shack and have not had the low battery since.
Mar 25, 2009 | Garmin StreetPilot c340 GPS Receiver
We cannot get our garmin c340 to acquire satellites.
turn it on and use it more ,even if going to grandmoms house ,for some reason they lose satelites when not in use.i found useing it or at least turning it on every day has cured the problem.hope this helps
Dec 28, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Why does my garmin c340 tell the wrong side of road a house is on?
This is common with most GPS receivers not just yours. It has to do with your position relative to the Sat. and the amount of processor utilization looking for triangulation readings. Basically its a brief signal deterioration on one or more signals so your device is lagging a bit.
please rate. thanks.
Mar 19, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 startup
The clue is that the voice is slowing and low pitch. The main processor time base has slowed... which means everything will be buggy.
First try would be to Reset the unit. Remove the face cover (GENTLY pry it loose by the fingernail groove directly under the GARMIN logo), press the RESET button, then reattach front cover... this is covered in the owners manual, available online.
If not, then it sounds like a hardware failure... time for a 1-800-800-1020 call (their customer service number)
Aug 06, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
168 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
