Question about Philips CDC745 CD Player
CD Player Won't Eject
Once closed, the player will not respond to the "open" button. The only way I can get the CDs out is to remove all of the screws and take the entire housing off the player. There does not appear to be anything broken inside, and the player moves freely back and forth as long as it is not fully closed.
fairlane
  • 50 Answers
SOURCE: CD Player Does Not Read CDs
Hi As you describe the problem, there are three likely possiblities, either the laser lense is dirty, the laser is beginning to fail, or there is a dead spot developing in the spin motor. Cleaning is the first step, and the least expensive...If you have some electronics experience, they are not difficult to clean, but you must expose the laser to do it, and I don't want to advise someone to do that, and forget to unplug the unit. It's free laser eye surgery, but I doubt you would be happy with the results. I would advise you to call around to local repair shops, and see what they charge to check it out and/or clean it, and then descide if it is worth proceeding. Hopr this helps, good luck!
Posted on May 02, 2007
SOURCE: dvd player won't open
I had the same problem for my panasonic dvd player (ht540). Neither of the above solutions worked so I found this one on the panasonic website:
1. turn off unit by holding down the POWER button for 10 seconds.
2. unplug the power cord and wait for one minute.
3. plug the cord back in and turn on the unit
4. when the dvd begins to play, press "EJECT".
It worked for me. The site for other troubleshooting is:
http://www2.panasonic.com/consumer-electronics/support/FAQs/details-FAQs+for+DVD+Recorders-UCM_PRD_CNT_001989#dvdrec6
Peter
Posted on Nov 16, 2007
leorcid
  • 281 Answers
SOURCE: az2025 CD PLAYER
The problem could be from your optical pick up, try cleaning it if you know how to do it without damaging it, if it doesn't work you will have to change it.
Posted on Dec 28, 2007
SOURCE: PHILIPS CDR778
My CDR778 display reads OPC ERROR .How do I reset it ?
Posted on Jun 23, 2008
SOURCE: Eject tray will not open when pressed, just comes up with blocked.
The small slot on the underside of the machine seems to be basically there to provide access to the manual opening lever (the white nub). That white nub popped the drawer open straight away for me. So now I have drawn an arrow on the underside to remind me which way to move the lever next time it happens! You can also move it the other way to get the disk to play. I also think you should never leave the machine without a disk in it - ejection of the empty drawer seems much harder for some reason. And possibly the ejection works better if you use the stop control on the remote instead of the eject button on the front of the machine.
Posted on Dec 15, 2008
Cd player doesn't play or ejects cds.it shows like there's cds inside but nothing comes out when the eject button is pushed.it displays"player error".what could be the problem?
The CD is probably not in the carousel the way it should be and cannot play and also has the door jammed so it can't eject. Sometimes this can be fixed by taking a thin object like a credit card and sliding in between the top of the door and the case. If you can move the CD just a little, you may be able to get it to eject.
Jan 28, 2011 | 2002 Buick Rendezvous
Cds are stuck in the default cd player of 2001 Dodge Intrepid. How do I get them out?
The first step is turning the car off. Then before turning the key back on, push and hold the Eject button then turn the ignition on. If the CD fails to eject then you can use a old CD and try to insert it into the CD Player, just as it try's to take your second CD pull it out and hit the Eject button again. This will usually get a Dodge CD player to Eject.
If this fails then the CD player must be removed and a manual eject can be performed.
May 15, 2010 | 2001 Dodge Intrepid
DVD side will not open, for the longest I could only get the DVD side to open if there was a disk in the slide yesterday the DVD side was closed with NO disk in it and now I can not open it
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. If this doesn't open the unit, you will have to unplug the unit and remove the cover. The cover is held in place by two silver screws on each side and five silver screws on the back of the unit. Once the cover screws have been removed, you can slide the cover towards the back halfway and then take the silver cover (held in place with two screws) off of the DVD player. Once the DVD cover is removed, insert a disc in the player and re-install the dvd cover and case cover. Plug the unit back in and eject and close the cover like normal. I have never tried to remove the magnet from the cover and checked to see if the DVD player still worked correctly. I have found it easier to just leave a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Apr 09, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
Philips DVP-3020K not eject my CD
hello my friend! my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Dec 21, 2008 | Philips DVP-3005 DVD Player
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Nov 15, 2008 | Cambridge Soundworks 740I CD Player
How do you eject the damn cd out of the pioneer DEH-P7900BT
Your Manual
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
will go over all the functions in detail.
3 EJECT button
Press to eject a CD from your built-in CD
player.
Press and hold to open or close the front
panel.
Bottom rightmost button.
Nov 11, 2008 | Pioneer DEH-P7900BT CD Player
DVD Player won't open
check if your dvd door is driving by belt or gear . if its belt ,check if its slack, if gear check for worn gear. weather gear or belt check if the motor driving it responds each time you press the eject button .check if the eject switch is ok .then if all this are ok ,check the ic controlling the eject/close functions
Jul 11, 2008 | Samsung DVD-V1000 DVD Player/VCR
CD player won't eject CD and does not recognize the CD
You will have to remove the player from your Sierra and disassemble it sufficiently to remove the stuck CD.
May 30, 2017 | Car Audio & Video
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Philips CDC745 CD Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
