Question about Sony KP-57WS500 57" Rear Projection Television
IC Convergence replacement
Hi sorry to bother once again... I have figured out that i pretty much need to replace IC`S in my KP-57ws500. People have mentioned that i should replace resistors, fuses, and maybe other things? So could you please give me the breakdown of what i should replace to fix a double vision, red arching line problem. I do have the part numbers for the IC but need some help figuring out what i should replace .Please HELP. Thanks
  • Sony Master
  • 8,617 Answers
You will no doubt need two STK392-560 ICs and quite possibly two 3.5 amp pico fuses, and its a good idea to get two 4.7 ohm 1/2 watt resistors as well. You can get all the parts you need at the following link and they will provide free installation instructions with pictures and free online tech support while you do the actual repair if you need it. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Oct 01, 2008
Can I manually adjust the convergence on a Sony KP 57WS500
that model has an auto focus so if thats not correcting the issue then the ICs will need replacment. The sony type 1 convergence repair kit from www.tvrepairworld.com should solve the issue.
Feb 22, 2011 | Sony KP-57WS500 57" Rear Projection...
Double picture out of alignment
Hi:
Your problem is its time to replace the convergence IC's. Replace both of them as if one has failed depending on which color is out of convergence the other is not far behind. They are the two large black IC's mounted on a large metal heatsink, also while replaceing them check the small yellow or green micro fuses underneath the IC's to make sure none of them have opened from the result of the IC failing.
Apr 30, 2010 | Sony KP-57WS500 57" Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
There are red, blue and green lines going all the way across
it sounds like a convergence problem; in the customer menu there is an option to adjust it with the Sony remote---if either blue or red will not adjust in some direction---you have a bad IC---this set uses two STK-392-560 IC chips for convergence---both would need to be replaced and the set adjusted again. If this has been helpful give me a vote here---if you need more direct assistance--------- etower.766@netzero.net
The convergence IC chips are available on Ebay from Surburban Electronics for less then 14 dollars for the pair.(plus shipping)
Aug 15, 2009 | Sony KP-57WS500 57" Rear Projection...
My tv experienced a sudden color shift with the blue moving to the left
Blue color moved to left because of failure of convergence out IC in TV
that need to be replaced. Call local TV repair shop to fix it.
Jul 13, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony 57" dlp TV CONVERGENCE problem
You have to pull the chasis completly out the set. Make sure you know where all the wires go that u have to unplug. Also u may need to change open resistors near the convergence amplifiers.
Apr 23, 2009 | Televison & Video
Convergence IC`S
Let me know do you have related service manual of Sony KP-57WS500 to guide you further?
Without service manual it would be difficult for you to understand our directions like what to check and where to go in TV etc.
Sep 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Kp-57ws500 sony projection tv convergence problem
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Jan 22, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 in.
Oh no it is less expensive to repair the printed circuit boards. You should buy only the IC,s that sony recomends you to buy. They will cost you more then a replacement IC will but they are not all alike even if they have the same numbers on them. Go to http://www.partstore.com and enter your model number and look for the STK IC. Don't forget to get some heatsink compound to install on the back of the new IC's before you reinstall them.. Remember to always double or triple check your work and make sure you have no solder bridges or shorts on the board. If you need a copy of the service manual, post your e-mail addy and I will send you one thru Pando. Pando is available online at www.pando.com for a free download. Pando lets you send large files via e-mail and the Sony manual is large. Good Luck
Mar 17, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
