Question about RCA Audio Players & Recorders
I have a RCA RS 2000 minibook shelf stereo and I can not find part I need the black latch that holds the CD cover down so the CD can play ,It is located at the right front under the CD cover,it is about 1 inch high & 3/8 of a inch thick the CD cover has a little *** on the right side that pushes into this latch & holds it down until you push down on it then it will release the cover so you can put in another CD...
  • 4,234 Answers
There are actually two types of this latch available. Can you tell if yours has a switch in it? You can tell if you can see the bottom. The one with the switch has 2 wire tabs on it.
Dan
Posted on Sep 30, 2008
RCA RS2000 CD Shelf System - CD Cover Latch
I was recently work on researching your item in the internet, and I was not able to found any supplier of this item or accessories. This only an advice, you can check the supplier where you bougth the said player possible they can give you any appropriate feedback regarding your problem. I am hoping that this will be a helpful information to solved your problem even though I was not able to solved your problem.
Please don't rate me until such other fixya will able to post their own opinion regarding your problem. Thank you.
Nov 29, 2007 | RCA RS2000 CD Shelf System
What rs remotes will work with a rca rs2610 book shelf stereo?
Remotes.com has a replacement remote that will work here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=+rs2610&uuid=14001121456810 . The original remote has the part number: ZA90459 . If you can find this remote, it would work. The other models of RCA RS stereo remotes won't work.
I hope this helps.
May 14, 2014 | RCA Televison & Video
Where is the aux jack for the RCA RS 2620 bookshelf stereo?
The Aux audio L/R input jacks are below the On/Off button on the left side of the front of the stereo's main unit. The headphone jack is just below the input jacks. You will probably need an adapter to split the stereo output from the Blackberry (probably a 3.5 mm stereo jack) to the L/R jacks.
Radio Shack has the manual for the RCA RS2620 here: http://support.radioshack.com/support_audio/doc72/72312.pdf .
I hope this helps.
Feb 04, 2012 | RCA RS2620 80-Watt 5-Disc Shelf System...
I have a rca rs 2663 stereo, The cd tray will not open or play cd's anymore. Could you please help
It two things can cause this:-
The motor is damaged ( you can listed closely to hear if the door motor runs when you try to open the tray.
Or The belt that takes power from motor to open mechanism is damaged.
Aug 19, 2011 | RCA RS2663 Shelf System
Rs 1286 rack system,cd tray not working properly,player wont read or play disc (made by rca)
If the radio and cassette work, then your CD lens needs to be cleaned. You can buy a cleaner CD, or you can do a better job by removing the case (MAKE SURE THE POWER IS OFF) and then clean the lens with a Q-Tip and denatured alcohol.
Feb 18, 2011 | RCA RS1286 CD Shelf System
I want to wire a subwoofer and amp to player
1. cd player connection, audio out (stereo) rca cable
2. from cd player rca cable, connect it to amplifier audio in (stereo).
3. speaker output wiring connection going to spkr. box.
Apr 16, 2010 | JVC FS-2000 Shelf System
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
