Question about Locks & Locksmithing
Rekeying kwikset locks
I was rekeying a deadbolt lock and the top pins fell out. is there a way to find out how to replace the pins back and what order.
  • unamazz Oct 01, 2008
    how about the springs where and when do the go in
  • 5 Answers
Sure. You need to install the key in the cylinder and keep it turned so the pins are on top. Then you install the pins one at a time in each hole until all the pins fit level with the top of the cylinder, You will probably have to re-arrange the pins once or twice to get the correct length in the correct hole but once all the pins are level you're home free.
Posted on Oct 01, 2008
The springs (which should be all the same length) go in the cylinder before the pins I believe. It's been a long time since I've done any lockwork so you might have to experiment. Lots of luck and hope I was some help.
Posted on Oct 02, 2008
Can i purchase multiple keypad deadbolt with same key?
Yes, Thank you for your inquiry; At FactoryLocks.com we carry Schlage BE365PLY505. The key number is stamped on the key. You can purchase the same entry on our website, factorylocks.com with your existing locks key number. Enter the 5 digit key code on our shopping page that is on the key. We'll get it keyed and out to you quickly.
May 09, 2014 | SCHLAGE LOCK COMPANY Schlage BE365VPLY505...
Kwickset door handle fell apart on my front door help
Kwikset locks are inexpensive because they do not have replaceable parts. Buy a new one.
By the time the lock breaks, it's probably time to get different keys, but if you have so many keys in the hands of people you cannot contact, or you have more than three other locks keyed alike, and you must have the new lock work with the same keys as before, the place where you buy new locks probably has someone who can rekey the new lock to your old keys. Kwikset also sells locks that you can rekey to other Kwikset keys yourself. They are more expensive than other locks of the same type, but could save money long term, especially if you find a need to rekey your locks a lot (lots of visitors, part-time tenants or roommates, your kids lose their keys a lot, etc.)
Sep 07, 2013 | Kwikset Professional Door Lock...
We have a kwikset smart key and the deadbolt part worked fine for months and then suddenly it won't work. Not happy. What to do? Shirley Johnson
You will have to buy a new lock once the "smartkey" locks up its toast. Very bad design unlike the traditional kwikset pin tumbler lock which can be repaired if something like this were to happen but hardly ever does.
Oct 22, 2010 | Kwikset Locks & Locksmithing
Kwikset SmartKey Error in Changing Key to Lock
Your out of luck this new design is terrible once it locks up and no keys turn it, the lock is done you will have to replace it use the traditional pin tumbler style kwikset and it can be rekeyed unlimited times by a locksmith with or without a key.
Apr 22, 2010 | Kwikset Professional Door Lock...
Kwikset Smart Key Deadbolt Won't Unlock
Kwikset Smart Key locks are complete junk. I am a locksmith and I am constantly going from house to house replacing these "dumb key" locks with original kwikset pin tumbler locks. What happens is either your key or the wafers inside the lock wear slightly, slightly enough to cause your keys to not turn, and since these locks cannot be picked due to a side bar system, they must be drilled off and thrown away when this happens Unless you have another access point to get in the house. If you do remove lock from the inside, throw it in the trash, buy original kwikset and replace.
Dec 13, 2009 | Kwikset Locks & Locksmithing
Kwikset smart key has no key. need to rekey. how do I do that
Here is the instructions from kwiksets website
http://www.kwikset.com/Files/PDF/SmartSeries/SmartKeyInsEnglishOnly.pdf
Oct 13, 2009 | Kwikset 907 907-L03 Lifetime Polished...
Key won't turn deadbolt
Try using your smartkey to "rekey" the lock to the original key... there's really no reason to buy the smartkey system unless you change locks alot... they are meant for the apartment industry more than anything I believe... in any case, the smartkey system allows you to rekey the lock without removing it from the door... so, use the original key and use the smartkey to rekey it or select a different cut and key it to that key... should solve your problem.
Last resort... take it back to HD for replacement.
Sep 09, 2009 | Kwikset Locks & Locksmithing
Lost entry door key, need to rekey kwikset deadbolt
Unfortunatley you need to have the key to remove the cylinder. You can take it to a locksmith that can pick" it to remove the cylinder and make you a key but it may be more cost effective to replace it.
Sorry not to be mre help.
May 21, 2009 | Kwikset Professional Door Lock...
Lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Mar 07, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
612 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
