Question about Hotpoint TDC32 Electric Dryer
Water leaking underneath when drying,whats the problem
Theres water leaking underneath the machine.somtimes the water container fills and other times its emty and gone on the floor
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Check your Vent. It's clogged or is too long...or restricted somewhere. Vents are critical...
Posted on Nov 04, 2008
  • Bob Henderson
    Bob Henderson Jan 26, 2010
    It is definitely...vent related. I had the same problem. My vent was both too long...and somewhat restricted. These blowers are very small, and won't move air very far. You have to keep that in mind when installing appliances Like this...
The water drains from the water container into the bottom of the unit. The water container does not leak, I have tested this by filling the container up and leaving it the sink. I have adjusted the...
Hi heeg_mark,
Leaks problem most often occurs when the water tank is not seated properly allowing water to drain out of the tank and into the base. There are alignment pins on the tank that fit into holes in the coffee machine. Make sure this alignment holes are clear of any debris. Coffee beans have been known to make their way into these openings. Please use a flashlight and a small mirror to see down into the alignment holes. You can easily fix this by following the steps below.
1. Please remove the water tank.
2. There is an access opening like a round hole in the base beneath were the tank fits into the machine.
3. Using an absorbent cloth material dry the water through this opening. Please be patient, it can take sometime.
4. Once the water is gone the machine will operate normally again.
Hope it helps.
Thank you for using FixYa.
Jan 09, 2011 | Miele CVA615 Espresso Machine
My Fisher Paykel gw612 leaking water from underneath during the spin cycle. I can't see any leaks underneath and the hoses and side of the machine stay dry. Also when it is filling it makes a slight...
my quess its a big job, check to see if there are any leaks from the motor, you may have faulty seals, also check the water seals around the electroncis board, once water gets into the motor it becomes a big job. i need more info.
Sep 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
I think my Whirlpool French door (freezer on bottom) is leaking underneath. I have checked the water lines on the outside and looked underneath and nothing. When I moved the fridge there was a film of...
check to make sure that the condensation pan is in its correct position,, somtimes when the unit is moved up steps it causes the pan to sit in there cocked or unlevel and will drain out excessively. or it may be a crack on the fill valve solinod where the water line connects to the fridge.. there will be a blue plasitc cover right where the water line connects to the frig and somtimes they crack and will only leak when the ice maker calls for water... pull out the frig and empty the ice tray and when you here it start to fill up the icemaker check around that solinoed be sure to use a bright flash light because sometimes the leak will be a little stream of water that is really hard to see sometimes you can only feel it with your fingers...I hope this helps......
Nov 11, 2009 | Whirlpool GX5FHDXT French Door...
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
COLD WATER
3 suggestions. 1st, make sure all of your valves are open. (some times installers forget to open them back up after the install) 2nd, fill the machine until the water gets hot. Check on the rear of the machine and make sure the hose going to the "COLD" valve is not hot (somtimes these hoses are reversed when they are installed) if those are both ok, then 3rd shut the water off and unscrew the cold side hose. (There is a screen underneath that can get covered with sediment from the house water supply and cause the water not to flow)
Jun 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Water leaking from underneath after washer drains
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaking
i got a vienna digital when i take the water container of to clean it 1 time out of 2 im gonna have water all over the floor what i do now clean the container put it back fill the water container with big glass and no more leak it probably have to do warp water container when it empty it seat perfectly when you have it in our hand it warp a little bit were not the only one with that me when i dont remove the container to fill it up i have no problem since then thanks for using fixya pierre
Feb 25, 2008 | Solis Master 5000 Espresso Machine
BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
Jan 29, 2008 | Hamilton Beach BrewStation Deluxe 47474...
Hotpoint TDC32 Electric Dryer Logo
452 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
