Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Oven starts, then shuts off; won't stay on
I press any oven function (bake, broil, convection bake, convection broil, pure convection, or clean), then I press the "+" time-temperature function button as instructed. The oven starts to heat, and if applicable, the fan starts running. Then, after four to twelve seconds, the oven shuts off.
We have had the stove for years, and this problem has only just now appeared.
  • 1 more comment
  • jim erickson Sep 30, 2008
    The fan works just fine. I just tried "convection bake" again and watched (and heard) it spin - until the whole process shut down, as it always does now.
    At first I thought the problem was related to the cancel-secure button, but that does not seem to be the case. When the stove is secured, by pressing that button for 4 seconds, nothing will operate at all (and the screen indicates "OFF"). Pressing the cancel-secure button again for 4 seconds unlocks the functions of all the buttons, but still the oven will only operate for a short time before shutting down.
    I question the latest suggestion, because it implies a circuit-breaker is disconnecting the electrical supply due to an overload, and then resetting, whereas in fact the range is never without power. In fact, if I press an operational button (say convection bake), and then the time-temp "+" key to get the oven operating, I can keep it going for an indefinite time period by simply re-pressing the convection bake button every four seconds or so. But as soon as I stop that intermittent button-pushing, the oven shuts down. There must be some sort of mis-guided electronic commmand shutting down the unit.
    I am posting to try to avoid having to call the service guy. I will do that if I have to, but that is a solution I have always had from the beginning. As to the possibility of it being a problem with the circuit, see my note above.
  • 2,071 Answers
This is a control panel board problem.Try to unplug the unit and leave it no power supply overnight in order the residual charge in the component parts is gone. The idea is to erase the memory stored in control panel. Then after the overnight,then replug again the unit.
Hope it may help you;
Regards,
VOTIT
Posted on Sep 30, 2008
    Sergeant:
  • 409 Answers
Hi jim,
may i suggest to check the keypad. this problem is intermittent which leads me to believe that you are loosing connection between the keypad and the control board behind it.
do you get any error messages on the display?
  • Carmen Mikulic Sep 30, 2008
    hi jim,
    no need to call the service guy, just check the keypad, control board and wiring harness.
    you should be able to figure this out yourself.
    Scholar:
  • 121 Answers
This a problem with your pc board the fan works the elements heats. I'm an appliance tech and run into this problem all the time. If this oven is a year or younger it's under warranty
    President:
  • 1,952 Answers
Check ur operating attenuator,solenoid,latch and entire wiring connection in ur device..
    Sergeant:
    Champion:
  • 435 Answers
Since, it works only for short time, I believe something is wrong with the circuit.
I would suggest you to call the service guy and fix it.
    President:
  • 1,263 Answers
You have an overload problem or your reset circuit breaker in the unit is weak. thus why it powers up and then shut's off. this only applies to the electric application. If you are using the gas feature it is most likely that your regulator is sensing back pressure and therefore shutting the valve body down
  • Ronald Mueller
    Ronald Mueller Sep 30, 2008
    it's obvious you have a power supply issue. As I stated earlier that it turns on and shut's off immediately means that there is an overload in your power circuit
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 71 Answers
Possibly something wrong with your fan, for example its blocked or just worked its self out and with the fan not running, the oven probably switches off as a saftey procedure. I reccomend seeing a repairman to have a look at it.
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven won't heat after self cleaning
There is a overload thermostat located on the rear of your oven that needs to be replaced.
Self cleaning operations are not recommended by this technician.
Mar 02, 2009 | Whirlpool Ovens
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Jul 05, 2008 | GE JBP90 Electric Kitchen Range
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
252 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
swDemonDog
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
