Question about Peg Perego Duette MT Newport Twin Stroller
Folding with seats in
I have the double and cant seem to figure out how to close it up with the seats attached if anyone has info on how to do this please help Thanks
    Scholar:
  • 135 Answers
It cannot be folded with both seats on. If I remember correctly, you may be able to leave the rear seat on, but the front seat needs to be removed for sure. It is a pain for sure to remove and replace the seats each time you get in and out of the car. Sorry. Congrats on your twins thwough. =)
If you would like to confirm, please download the user manual from the Perego website.
Good Luck! from Moms Just Know
Posted on Oct 24, 2008
The rear double seat of my 2013 Mitsubishi Mirage won't raise after folding down due to not enough play in the middle seat belt. How can I release the seat belt to lift the seat again?
sorry but seat belt reel is jammed ,,,, find reel and prob will have to replace it ,,, dont play with safety belts or reels they are too important
Dec 01, 2013 | Cars & Trucks
I have a double stroller and i cant put car seat in
I could not find much, is there a name of the model, the number did not list? Try this link and see if anything looks like yours... http://www.fixya.com/support/safety_1st/strollers
Jan 09, 2013 | Baby Gear
04 Lincoln Navigator folding mirrors, seat memory, seat dont work
most likely a pinched wire around the seat causing a short to the seat frame every once in a while when the seat is in the right place. start with checking stuff that moves most often (driver's memory seat)
Aug 16, 2009 | 2005 Lincoln Navigator
My rear folding seats wont fold down to allow me access to my trunk. i know they lock, but my owners manual is locked in the trunk and i do not know how to unlock the folding seats.
When you open the trunk, there should be a knob at the top right of the opening. Pull that and it will unlock the locking mechanism for the rear seats. I just recently figured that one out myself!
Jul 08, 2009 | 1999 Volkswagen Cabrio
Laying Down and Folding Maclaren Triumph Stroller
Folding takes some getting used to, broke the first one I had because I used force. Here are some step by step instructions...http://www.strollerreviewguide.com/how_to_unfold_and_fold_maclaren_stroller_step_by_step
-Good Luck!
Feb 10, 2009 | Maclaren Triumph W0806063 - Navy Umbrella...
How do I fold up DuoGlider???
Folding up duoglider. Fold the botom basket down. I always take off the front wind breaker ( infants cover). It will just pop right off. Then locate the front handle of glider, slide red button to the right and twist.
Jan 17, 2009 | Graco DuoGlider LXI 7951GGG Twin Seat...
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Jan 04, 2009 | 1989 Ford Mustang
Folding the Peg Perego Tender??
Download the complete manual here. http://www.pegperego.com/page.php?sid=e255b47f0e899dedb0e68510cd054119&pageid=UJVNL001&idp=0000000169&pg=05&cl=N
I have copied only the closing instructions for you below, but you may need the complete manual if you are not familiar with all the parts.
CLOSING
27• Use the brake and raise the compass devices of
the hoods.
28• Make the front wheels swivel, leaving them
turned toward the front.
29• If they have been used, lower the Ganciomatic
System’s attachments by fi rst raising the
fabric from the seat as indicated in the fi gure,
then pressing the tongues on the inside, as
indicated by the arrow. See also Point 38.
30• Pull up the two levers on the handlebar to
release the catch.
31• Release the brake and use your left foot to
press the safety lever.
32• Push the handlebar down, press until the last
click when the stroller closes automatically.
33• Make sure the stroller is closed correctly, by
the safety hook, as indicated in the fi gure. The
stroller is free standing when closed.
Dec 28, 2008 | Peg Perego Tender Blu Moon Twin Seat...
The back seat not going up .
The double seat actually gets caught on the bottom of the second row seat cover. If you move the second row middle seat forward a couple of inches it will release the rear folding seat and allow it to return to the upright position. You can also reach inside the back seat and push the seat cover ( which by the way has a metal bar in it ) forward to release the rear seat.
Oct 10, 2008 | 2004 Ford Expedition
Peg Perego Duette MT Newport Twin Stroller Logo
115 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
romney2012
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
