Question about HP OfficeJet 7410 All-In-One InkJet Printer
How do you set the date/time?!
Have attempted to set it using the menu on the machine but suppose it has to be done with software. Will appreciate help on this... so the fax machine sends the right day and time. Thanks.
    Scholar:
  • 45 Answers
Press "Setup", "4" (B asic Fax), "1" (Date and Time).
Enter Month, Day, Year, Hour, Minutes, 1=AM, 2=PM through the keypad.
Posted on Oct 01, 2008
DVR-535 Genius, I am trying to set the Time and Date. the quick quide that comes with the DVR does not mention how this is done.
first of all press menu then down button to down "date and time" then press menu go down to "date input" press rec button go down to set then press rec button use press menu button till u done time snd dste setup press menu buton to home screen check the date and time in red at botton see if correct or redo as listed here
Sep 20, 2013 | Cameras
How do I change the time on the Brother 2820 fax?
This was taken directly from the Brother 2820 Manual:
Setting the Time
When the machine is not in use it will display the date and time. If you set up the Station ID the date and time displayed by your machine will be printed on every fax you send. If there is a power failure, you may have to reset the date and time. No other settings will be affected.
1 Press Menu/Set, 0, 2.
[2. Date/Time]
2 Enter the last two digits of the year.
Press Menu/Set.
3 Enter two digits for the month.
Press Menu/Set.
(For example, enter 09 for September,
or 10 for October.)
4 Enter two digits for the day.
Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time
whenever the machine is idle in Fax
mode.
When the machine is in Sleep mode, the
LCD shows Sleep. (See Sleep Time on
page 2-8.)
Turning on Automatic Daylight Savings Time
You can set the machine to change automatically for Daylight Savings Time. It will reset itself forward one hour in the Spring and backward one hour in the Fall. Make sure you have set the correct date and time in the Date/Time setting.
1 Press Menu/Set, 1, 5.
[5. Auto Daylight]
2 Press Up Arrow or Down Arrow to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
May 03, 2011 | Brother IntelliFax-2820 Laser Fax
How do I set the date and time spamp on a Canon A490
Hello and Welcome to FixYa!
To set the date and time stamp on pictures, Follow the given instructions:
Setting Date and Time:
First of all set the exact and time if your camera:
  • Press the "Menu" button on the camera and use the right navigation button to choose the "Set Up" menu.
  • Scroll down to "Date/Time" and press the ""Func./Set" button. The set date and time will appear on the screen, and the month unit will flash.
  • Adjust the month unit by pressing the up or down navigation buttons. Move to the day unit by pressing the right navigation button. Use the same instructions to adjust each unit of the date and time.Push the "Func./Set" button to save the time and date settings.
Setting Date Stamp on pictures:
  • Press the "Func./Set" button and select "Recording Pixels" and "Postcard". The camera is now set to "Postcard" mode.
  • Open the "Rec." menu by pressing the "Menu" button on the back of the camera.
  • Highlight "Date Stamp" by pressing the down navigation button.
  • Change the "Date Stamp" setting by pressing the right or left navigation button. Your choices are "Off", "Date" or "Date/Time". Now, when you take photographs the date or the date and time will appear on the picture.
If this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 11, 2011 | Canon PowerShot A490 Digital Camera
Hello we have a Brother 2820 Fax Machine and we cannot find the Instruction Manual and we need to reset the time can you please advise us on how to do it. Thanks Marie
1Press Menu/Set, 0, 2.
2 Enter the last two digits of the year. Press Menu/Set.
3 Enter two digits for the month. Press Menu/Set.
(For example, enter 09 for September, or 10 for October.)
4 Enter two digits for the day. Press Menu/Set.
5 Enter the time in 24-Hour format. Press Menu/Set.
6 Press Stop/Exit.
The LCD now shows the date and time whenever the machine is idle in Fax mode.
When the machine is in Sleep mode, the LCD shows Sleep. (See Sleep Time on page 2-8.)
Hopefully that worked correctly and solved your problem!
Apr 07, 2011 | Brother Office Equipment & Supplies
HOW DO I SET THE DATE & TIME ON THE ANSWERING MACHINE DS6221-1
Hi there, I found my manual that states:
Press MENU/SELECT to display menu when in idle mode.
Press the up or down triangles to reach DATE/TIME. Press MENU/SELECT.
Use the keypad to set the year. Press MENU/SELECT.
Use the keypad to set the date. Press MENU/SELECT,
Use the keypad to set the time. Press the up or down triangles to select a.m. or p.m. Press MENU/SELECT
The screen displays STORED and you'll hear a confirmation beep.
George Rocks
Apr 18, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
How to set date and time for uniden model XDECT 7055 + 1
you have to do it from the hand set, go into menu, using the arrows scroll down to date and time , use the arrows to select date , then hit select do the same for the time, then when the am option flashes use arrows then select , then its done , hope this helps
Dec 14, 2009 | Uniden Cordless Phone
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Lands Phones
Date/time imprint. Coolpix 2100
This can be done with photo editing software like photo shop on you computer. hope this helps. it the photo was already taken with the time stamp on at the time of the photo it will be on the photo and the only way to get rid of it is software. Hope this helps. please let me help you before you leave a thanks for tring feed back.
Aug 02, 2007 | Nikon Coolpix SQ Digital Camera
HP OfficeJet 7410 All-In-One InkJet Printer Logo
113 people viewed this question
Seeker5211
Seeker5211
