Question about Intel Motherboard
Beep codes i have a GA 7n4oo Pro2 and are looking for the beep codes
    Problem Solver:
  • 29 Answers
You have to go to the manufacture site on line for the codes.
Posted on Sep 30, 2008
Do gigabyte motherboards GA-7N400 pro2/GA-7N400/GA-7N400L support usb3 cards
Yes, but please make sure you buy the PCI interface version, some of available USB 3.0 card in the market are mostly PCI-express interface. Just tell the store you will install it on the old PCI slot (white one). You also ask them if they have issue with the card that they recommending to you.
Nov 04, 2011 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Computer was shut down abnormally following a power failure in a thunder storm. No apparent physical damage to machine but will not reboot. Machine gives single long beeps at 6 second intervals. BIOS is...
take out the processor chip and clock battery along with the ram while it is disconnected from the wall outlet and wait about 5 mins. after you put it back together, if the problem persists the processor might need to be replaced or the entire motherboard its self.
Jun 28, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
GA-7N400 Pro2 at startup i hawe long separate continus beeps
Possibly Ram, try and see if removing and replacing helps
Other causes may be voltage issues ( check the bios and see what the various rails are telling you)
eg: there should be readings for 12 volts 5 volts and 3 volts, if any are + or - by 10%, there is an issue with the voltge controller. You might want to try a replacement PSU?
After this.. bad video ( check by installing a video card)
Temperature warnings ( check in bios to see under PC health status) what the cpu and board temps are running at, if above 70 degrees...overheating issue or more likely at start up, board thinks that the CPU fan is not running fast enough or not working. If fan IS working, you have a problem with the CPU fan sensor, will need to replace mobo
Jan 27, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
GA-7N400 Pro2 - GIGA-BYTE i need motherboard driver
can you try this link below:<br /><br /><a href=""><br /></a><br />hope that was helpfull<br /><br />
Aug 30, 2010 | Gigabyte GA-7N400 Pro2 Motherboard
How to disable raid feature on ga-7n400 pro2 motherboard
For starters you read your Instruction Manual or User Guide and you will find it there. If you have no manual, you will need to go to our sales department and buy one. CONSTANTIN (arzconst)
Jul 05, 2009 | Gigabyte GA-7N400 Pro2 Motherboard
Beeps but wont boot
some hard ware problem i think..try to replace RAM ...
Dec 03, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Ga gigabyte mainboard trouble
Just because it doesnt beep doesnt mean the vid is not gone
place board on a non metal surface hooked to
cpu with heatsink and fan attached
plug power supply in (will not shock you just dont lick it ok)
if board does not come on take a small flat head screw driver look at where the power wire would slide on cross those two pins should come on. again will not shock you.
still no video try pci (most basic video mobos support) card
still no video could be cpu I have had several of these be bad caouse no video also
try anouther cpu same setup
still no vid mobo shot sorry
Oct 24, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
clear your bios setup with jumper settings.
take your cmos cell 15 minutes then put in position.
also check smps.
power cable,power supply.
Mar 26, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
Where to find manuals & Drivers
Here is the link for the drivers, bios, manuals, etc of this motherboard.
Good luck
Nov 01, 2007 | Gigabyte GA-7N400 Pro2 Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
