My dell laptop will not connect to linksys 54g ,why
    Scholar:
  • 67 Answers
Let me try to solve this. Please try to see if the wireless antenna switch (physical switch) is turned on. For Vista, please click on Start-Connect to- then please select your network. If it says you are connected to the network, please click on "Open Network and Sharing Center to see if there is a red x mark between "network" and "internet". If there is none, please launch your browser (Internet Explorer) If there is, please click on that red x and see what is the message after. If it could not be identified, please contact your Internet Service Provider (ISP). If there is no problem with your ISP, please go to Start-Control Panel-Network and Internet-Internet Options-General Tab-Delete (Under Browsing History)-Delete All. After these, please try to launch your IE. You can also download the latest driver for your wireless network adapter using a different computer if the first offered solutions did not work. Please let me know if any of these works. Thank you.
Posted on Oct 01, 2008
Just had a new wireless card fitted and I am trying to connect to my router
I recently purchased a new wireless card for my desktop, it was a Linksys 54g with speedbooster but after the switch the networks I was connecting to (Free wireless from my apartments) will no longer connect. The old card that I had was just an offbrand card which used the microsoft zero connection tool to configure, this new card attemps to use the software included and ive tried to switch between the two different connection configuration tools both can detect the routers but when trying to connect it does not even get to the aquiring access key stage. the router is not passworded so I guess I was just wondering can this new card not connect to the router maybe due to brands? possibly the router is belkin or something of that sort and this linksys card cannot connect? I had before gotten it to connect at the very good 54kbps or whatever the number is but it would not let me access internet and then said limited/no connectivity. I also tried to change the settings on my wireless card and set them to 802.11b only, 54g auto, 54g LRS or Performance but all had the same result, I switched the default channel to match that of the router as well still nothing.
dell inspiron 1525 battery
Oct 03, 2010 | Dell Inspiron 1525 Laptop
On my windows vista dell laptop it say limited acess to linksys
"Limited access or no connectivity" message comes when there is issue in ip configuration for that enable DHCP in router then set ip get automatic in your windows network adapter's tcp ip property. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then enable DHCP save settings and restart router then go to your windows network adapter tcp ip property then set ip get automatic.Then it will work fine. Let me know if you need further assistance. Thanks for using FixYa.
Aug 06, 2010 | Linksys WCG200 Wireless Cable Modem 54G...
MY WIRELESS-G LINKSY 54G NOT DEFAUT IP ADDRESS 192.168.1.1 BUT DEFAUT PRIVATE IP
The Linksys configuration URL IP address is 192.168.1.1 this is used to configure the Linksys wireless settings.
The Linksys is also a router and will issue IP address to eack computer that connects to it (LAN and wireless). it will start issusing IP addresses starting at 192.168.1.2 and the last number will increment by one digit as each computer connects to the Linksys.
Jan 21, 2010 | Linksys Wireless-G WRT54GS Router...
Have a WRK-54G Linksys wireless router. Have a
I had a TEW-421 card for a time, and it can not do WPA encryption, only WEP. It's not a driver shortcoming, it's the hardware in the TEW-421 card.
Sorry to tell you it's a dead-end, but at least now you know.
Oct 18, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Jun 01, 2009 | Dell Inspiron 6400 Notebook
1 forgot my passwords for each computer on linksys router 54G
You can press the reset button on the back for a minute and it will reset the router back to default.
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Dec 28, 2008 | Linksys Wireless-G WRT54GS Router...
Internet access problem with a Linksys 54g router
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Jun 20, 2008 | Computers & Internet
Cannot access router webpage
Make sure your firewall and anti-virus are switched of then try and connect to the webpage
Jun 13, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
