I have a wf321p hotpoint aquarius washing machine. it never stops draining.
What happens is that when I try to start a cycle the on/off light starts to flash along with the mini load light and the rinse hold light. The machine will not stop draining water hereby water is also coming in non stop. I have cleaned out the filter and checked all the hoses for blockages. Please can you try and help me with this as I hardly have any clothes left lol.
Thanks a lot I have a Hotpoint WF503 and mine is doing the exact same thing. I'd love some help if anyone knows a solution. :)
    Top Expert:
  • 867 Answers
The issue you have is actually one i have come across on several occasions, these models have a couple of weaknesses in the electronics, it the door latch fails then it can feed voltage back into the electronics and cause all sorts of odd issues, unfortunately it's a matter of replacing the electronic controller and then see what else if faulty, in most cases it's cheaper to replace the machine.
Posted on May 15, 2017
  • 38 Answers
SOURCE: Hotpoint Aquarius WD440 Error
you will find your filter is blocked
Posted on Jul 26, 2007
  • 3 Answers
SOURCE: hotpoint aquarius wt540 wont pump out water
Hiya Barry, I have the same machine and for the last 3 days have had the exact same load and reduced crease as well as power light flash right when it comes to drain...?
I have scratched my head and done lots and lots of research, reckon I could design and build my own washer now lol, anyway, I fitted a new pump and ran it, thinking this is it sorted, went out and got a call from our lass...doing it again.
Right, gonna have to get me hands dirty...I removed the drain hose (Ignore the pump for a second, I'm talking about the grey hose that goes from the pump to the sink) from the sink and poked my fingers as far as they would go...debris, I then removed it from the other end (Pump) so I had a long hose in my hands, not attached to anything at either end....cleared it and again, loads of debris (Fluff, plastic etc) and put it all back together...turned the old fella back on and running a wash right now as we speak...happily spinning round at 1400rpm and throwing gallons of water down the sink...I would consider it fixed.
So I can most definately tell you that you have a blockage somewhere mate, I'd get your hands in the toolbox and pull that pipe off, doesn't require any level of experience, just the ability to put things back as you found them...
Hope that helps
Posted on Dec 01, 2008
SOURCE: Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
Posted on Jan 22, 2009
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Posted on May 27, 2009
  • 278 Answers
SOURCE: rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Posted on Oct 15, 2009
Hi there, My washing machine is hotpoint WTL500
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing.
Any idea what's going on there pls.
Aug 11, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
Feb 03, 2010 | Hotpoint Washing Machines
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd420
Check if the hose from the tub to the drain area has come off; refit carefully. This could happen if the tub is unbalanced, happens sometimes.
Pl rate if helped..................
Dec 28, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
