Question about Minolta Office Equipment & Supplies
Showing mafunction -code c-0600
MY Minolta di520 is reporting a mafunction -code c-0600. what can I do?
  • Minolta Master
  • 6,359 Answers
Scanner motor failure, that is the motor that run the big bright light under the big glass. open the front door, small access palte upper left remove cover press trouble reset if the code come back replace the lamp
try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Nov 22, 2015
5 Suggested Answers
  • 300 Answers
SOURCE: Minolta Di520
From the service manual
These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and
communications. For remedial action change the board, check for cable connections, and turn OFF
and ON the power.
C133B - Check cables for proper connection and, if they are okay, change the finisher cpu board.
Hope this helps!
Posted on May 19, 2008
SOURCE: minolta di520
es el pote fraSCO DEL TONER
AT THE TONER WHERE IS
Posted on Sep 30, 2008
mr_kairo
SOURCE: minolta di 520 -malfunctioning code c 0600
Encoder pulses are not input to SCP Board PWB-IC at
50-msec. intervals while M31 is turning.
Posted on Jul 15, 2009
  • 1297 Answers
SOURCE: Reporting a malfunctioning code c-0600
Change the scanner motor driver board,immediatly right side to scanner motor including integrated circuit STK 681050.100% this is the problem,STK in shortcircuit pin 4,5 out.
Posted on Jul 30, 2009
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Minolta DiALTA Di520 Laser Printer code 13f1
Replace the print head the device that houses the machine LASER, or the J or A printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
Jan 22, 2013 | Minolta DiALTA Di520 Laser Printer
My copier minolta 520 was not working error code c13f1
sir/mam Replace the print head the device that houses the machine LASER, or the "J" or "A" printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
Nov 18, 2012 | Minolta DiALTA Di520 Laser Printer
Fault code C-of24 ? Minolta Di520 Laser Printer
Remove the drum cartridge then the drum and clean the sensor that monitors the drum. If not then replace the drum and or the sensor and board.
Sep 04, 2012 | Minolta DiALTA Di520 Laser Printer
Minolta di520 error code C0990
Large capacity draw bottom draw lift problem. gear might be bad or the cable snapped.
Aug 13, 2012 | Minolta DiALTA Di520 Laser Printer
Nov 09, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta di 520 -malfunctioning code c 0600
Error C0600 is a scanner motor malfunction. It's either the motor (M31), or one of the control circuits (PWB-IB or PWB-IC)
Sep 30, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta di520
Jul 17, 2008 | Minolta DiALTA Di520 Laser Printer
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
