Toshiba 20wlt56 lcd tv, digital tuner has stopped working
In the middle of watching a digital broadcast, the picture froze. It would not respond to the Remote except for a couple of functions eg Volume, Source Select, Picture in Picture. If the source is changed to Analogue/AV etc it works fine but as soon as I change source back to Digital the screen displays a frozen image of the last thing displayed before changing source.
Toshiba Helpline suggested removing the power input for 5 seconds to reset the TV but that did not work - I even left it disconnected overnight without success! She said that there is a Factory Reset option hidden away in the menu, but it's in the Digital menu which I can't access!
Is there any other way to reset it, or is it likely to be a repair job? If a repair, anyone have an idea of the likely cost?
  • Anonymous Jan 03, 2009
    I have the same trobule....
  • john992 Feb 19, 2009
    I have the same issue with my Proline TV. It was working ok then I started flicking through the channels and it lost signal. It stated "No signal input" so I checked all the cables and they were ok. Tried the analogue and DVD player both worked ok. Called Comet and was also advised to reset it via the menu (although this couldn't be accessed as it was frozen). Comet recommened taking it in and as it was 1 month out of warranty we would have to pay. At present they are looking at it (it having been sent away) and they are doing that for free as we complained but if they find it needs a new part they said we will have to pay. I hope we get a solution to thi issue as it seems common looking on the net but not worth the repair bill.
3 Suggested Answers
  • 1622 Answers
SOURCE: NEC - Model NLT-32HDB2. The DTV (digital receiver)
You can fix this, all that is needed is to carefully understanding the electronics parts used and having little of basic knowledge in electronics.
The problem is in either power supply or the Y sustain board. The Y sustain board is are relatively large board if out of which go connections to the side of the display , it therefore closer to either the left or the right side of the display , has at least one rather large heat sink on it and far power cables connecting it to the mains power supply .
Often there are fuses on that board , one or more , check them
If they are blown you can try to replace them, but expect them to blow again , usually the whole board needs to be replaced.
Often that need to be done in a service center as there are some adjustment to be made after replacement.
Posted on Aug 22, 2010
SD Tech
  • 14553 Answers
SOURCE: no digital channels or menus
Yes, the main tuner is likely bad.
Posted on Jun 13, 2012
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
Can you please advise which external tv tuner will work for SONY trinitron kv-xf21m80 model? My SONY crt tv tuner is not catching most VHF B/G channels. i sought the services of an authorised service...
If you have a cable box and can set your TV to channel 3 then you should be able to watch cable. If you want to watch over the air broadcasts then you need a digital converter box which you can buy at Best Buy for around 40 dollars. You use the converter box as the tuner and set your TV on channel 3.
Dec 24, 2012 | Televison & Video
Model 55ht1u
Sorry, but I couldn't find any mention of P'n'P in this model's specifications.
Looks, like it just not equipped with that. Look at your Toshiba's remote control: if you don't see any PiP related buttons, it just not there. Definitely, has only one tuner, not for 2 tuner P'n'P broadcast. Some TVs must use external signal source for this feature, like an extra set top tuner box or DVD recorder with it's own ATSC tuner.
you may check TV's specs at: .
good luck,
Jan 02, 2012 | Toshiba Televison & Video
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Toshiba 20AF42 is the tuner Digital or Analog? Chassis M3K62
This tv is a Analoge tv.Only can be able to used with CABLE,SATALITES or some other pay tv services to able to get a picture.Can't used the alone trying to recieving the DTV free AIR signal,will not work.Only way to get free AIR DTV to work for this tv is.This tv must have a Digital Coverter box hook up.The free AIR broadcasting signal must go through the tv Digital Converter box to be able to watch Free AIR DTV channels broadcasting.
Sep 04, 2011 | Toshiba 20a43 20" TV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
I have a model no. 32HLC56 TV. Everything seems to work fine, except the color of football fields. They come in gray instead of green. However, other things, such as uniforms that are supposed to be...
Take this tv set test it with other tv incomming tv signal cable in ur house or take another tv test this incomming broadcasting signal cable.If it is the tv,not the incomming broadcasting signal cable.The tv Tuner signal board is the causes and it is dying.Tries websites like, to buy a refurbish tv Tuner signal board for the replacemennt.
Dec 09, 2010 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Tv works but picture is showing in blue
If the picture is blue only and there is no red or green, you have either colour gun failures or if you are trying to watch a picture from a component source there maybe something wrong with the red and green cable feeds. Try watching a DVD using a single composite video feed (usually a yellow RCA plug). If this unit has an internal tuner (either analogue or digital) and you still only see blue broadcasts then you have a problem. Whether this unit is an LCD or CRT rear projection TV the repairs will probably be expensive. Ultimately, it is not a user repairable device and needs a qualified Sony tech to undertake the work.
Sep 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Dec 06, 2008 | Sharp LC-19SB25U 19 in. LCD HDTV
HD ready does not mean it has a digital tuner.
don't know what TV model you have but any TV with a coaxial connector will receive the analog broadcast. However; if your TV is not equipted with a digital tuner, you will need a set top box when analog broadcasts stop transmitting in Feb.
Aug 21, 2008 | Televison & Video
Televison & Video Logo
385 people viewed this question
Top Televison & Video Experts
