Lexmark products work best with genuine supplies. Lexmark does not recommend the use of refilled, remanufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
You can try to clean your cartridge nozzles using the Lexmark software on your computer. From your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If that does not help, maybe it would be best to replace your supplies with genuine cartridges.
I hope this helps.
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
SOURCE: Lexmark x1270 not printing in color
Is the cartridge a Lexmark cartridge or a refilled cartridge?
Remove the cartridge from the printer, take a damp paper towell and wipe the cartridge in one direction on the bottom. Is Ink coming out? If yes then put the cartridge back in the printer and try to print again. If the answer is no and the cartridge is brand new you need to return it to you point of sale and get a new one as its a bad cartridge.
If the cartridge is a refilled cartridge that is probably the problem. Lexmark printers do not support refilled cartridges.
Thanks
Catherine
SOURCE: lexmark x1270 paper jam
hah - I had this problem on my old 1270 - there is a jam - its just very small - mine was caused by half a peanut lodged under a pickup roller - take the back paper guide off and check carefully - it might just be a piece of grit - the paper will skew away from the point of the jam so see where it skews and check around there
hope this helps, cheers
SOURCE: lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
