Question about Ricoh Aficio AP400N Laser Printer
RICOH AFICIO AP400N - HOW DO YOU REFILL THE CARTRIDGE
Does anybody have instructions on how to refill this particular cartridge?
Thank you,
George
  • 24 Answers
this is a all in one unit. and available as supply,
Posted on Oct 05, 2008
How do I reset the alert light still on to off ? after refill black toner ?
Replace the chip, or mite have a RFID chip then you need a new cartridge
Nov 18, 2015 | Ricoh Aficio Sp C222dn Color Laser Printer...
Tone Life End
Generally when you purchase a brand new Printer then the company provide a introductory cartridge but you must purchase a new cartridge and after the tone empty you can either refill it or buy a new one
Tips : if you are using printer regularly then you do not required to purchase another one, you can refill it from your nearby cartridge refilling shop.
Mar 19, 2013 | Ricoh Aficio SP 1200SF
RICOH AFICIO GX3000 SF. PURCHASED OCT 2009. SERIAL R3178000026. RAN OUT OF MAGENTA COLOUR. REPLACED WITH REFILL. WORKED FOR ONE DAY THEN MESSAGE SAID REPLACE MAGENTA CARTRIDGE AGAIN. ASSUMED CARTRIDGE...
There is a computer chip in the cartridges that monitors the ink level. If you are going to refill the cartridge instead of purchasing a new one, the only way to make that work is to stop using it before it gets low enough to trigger the comuter chip. When the ink level goes low enough to report it is running out, there is no turning back for that cartridge. If you refill before that point, they usually continue operating as normal.
There are numerous problems with using the refill method instead of purchasing a new cartridge. Once the seal is broken to add ink, they can leak into the printer and cause damage. Companies that sell refilled cartridges can replace the ink level sensor and by pass the problem to guaranty their product will work in your printer. Using refilled cartridges voids your warranty, so I will not suggest using them.
Now lets work on the problem with your printer and get it running again.
I have a couple of questions for you.
You mentioned you used a refilled cartridge and it worked for a day before it stopped. You also said you contacted a supplier who sent a replacement.
Please clarify the following for me:
Did you refill a cartridge yourself and it worked for a day before stopping, and then you bought another cartridge from a supplier and it still does not work? If this is the case, tell me what happens when you try to print? Does the unit not respond? Is there an error on the display? Does the printer say its out of ink when you try and print? Are there flashing lights indicating a problem? When you removed the old cartridge and inserted the fitted replacement, did the printer recognize that a catridge had been removed and then recognize that a new cartridge was installed?
Troubleshooting instructions depend on your answers to the above. Please send me your answers using the comment or reply link next to your question posted on Fixya. Or email me at kndkcook@aol.com.
Did you buy a refilled cartridge from a company who sells them and it worked for a day before stopping so you contacted the supplier who gave you another refilled cartridge which still does not work?
If so, please tell me what happens when you try and print? Is the unit responding? Remove the cartridge from the printer. Turn the printer off, leaving the cartridge out. Wait a minute or so and turn it back on. Does the printer say that the cartridge is missing or not installed? Put the cartridge back in the unit, and tell me if it recognizes that a cartridge has been installed? Does the printer say the cartridge is still out of ink? Is there an error code on the display? If so, what is it?
If there are no errors displayed and the problem is that the printer just does not do anything when you try and print with the cartridge installed - then check for pending documents in your print que that might need to be deleted. Pending documents will cause it not to print until cleared.
To check your print que, click on the arrow next to the clock on the bottom right side of your pc screen. See if there is a picture of a printer and if so, right click with your mouse on top of that Icon and open the print que. If you see documents pending, click on each one and choose delete or cancel until there are none left. Once the que is empty, try printing a test page and see if this solves your issue.
Please send your answers to clarify the problem as soon as possible and I will help you troubleshoot and repair this printer. Thank you for using Fixya!
Nov 23, 2011 | Ricoh Aficio GX3000 All-In-One Printer
How to refill ink
Purchase a refilling ink kit for your model printer and it will come with instruction on how to refill the ink cartridges. Instructions will vary with different printer cartridges.
Mar 26, 2011 | Ricoh Aficio GX3000 All-In-One Printer
How do you refill fuser oil on a aficio CL7000? and where do i find it to replace it?
It is a fuser oil cartridge. When you replace it the counter gets reset automatically. It is located on top of the fuser unit. This is the part that gets hot and is located right where the paper exits the printer. It is accessed from the left side upper doors. Here is a link to a site that sells the unit as well as all the parts and supplies for your printer. The top picture on this link is the fuser oil cartridge so you can see what it looks like which will assist you in locating the unit in your printer.
Installation instructions are included in the box with the new oil cartridge.
http://www.precisionroller.com/search.php?q=cl7000+fuser+oil
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 28, 2011 | Ricoh Aficio CL7000 Laser Printer
How do I refill the Ricoh SC P400 cartridges and replace the chip?
the cartridge cannot be refilled and chip cannot be changed. you have to replace the whole cartridge. Ricoh don't refill laser printer cartridges mate. I work in Ricoh.
Jan 04, 2011 | Ricoh Aficio SP C410DN Laser Printer
Can we refill the ink toner of ricoh MP 1600 le
A laser printer does not use ink, it uses toner powder. This powder is very fine and it is not wise to breath in this powder. I suggest you either purchase a recharged toner cartridge or a new toner cartridge for your model laser printer.
Oct 23, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
I need to reset the cartridge chip gx3000
how to reset the chip in ricoh gx3000colour printer
Jun 16, 2010 | Ricoh Aficio GX3050 GelSprinter
Installed new black toner but it still indicates it is empty and nothing will print!
Did you install a brand new cartridge? Or did you refill the old cartridge?
Ricoh has "smart chips" in the toner cartridges, and those tell the printer how much toner is used. If you refill the toner,the smart chip must BE REPLACED, the old chip will remain stuck at "empty".
Sucks, that Ricoh for you. That why that printer was $160 on Woot. LOL.
(Yea, I got suckered in too...)
Oct 13, 2009 | Ricoh SP C220N Aficio Laser Printer
Refill cartrige
Yes using those refill kits but it can be sometimes hard doing it yourself. Sometimes it easier taking it to a shop such as cartridge world and get them to refill it
Sep 22, 2009 | Office Equipment & Supplies
Ricoh Aficio AP400N Laser Printer Logo
179 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
