Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Kitchen aid side by side 2003 KSC... freezer not freezing
My 5 yr old s/by/s kitchen aid refrig/freezer appears to be warming up. It makes a random clicking sound & possibly a strange odor can be detected by some with sensitivity to odors.
    New Friend:
  • 161 Answers
Sounds to me like a bad compressor....might want to have that looked at by a pro.
Posted on Sep 30, 2008
How to defrost freezer in kitchen Aid bottom drawer freezer
My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
Sep 10, 2013 | KitchenAid Refrigerators
My refrig just stopped cooling/freezing. 6/7 yr old side by side Amana asd262rhrw. the motor has been louder lately
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Refrigerators
Kitchen aid KSRG25FKSS04 freezer is not freezing
Hello, few things to check:
1) Remove dirt / dust that has accumulated on the condenser coil located on the back of the fridge, or underneath. Use a vacuum to clean off with.
2) Remove dirt / dust in / around compressor area. Make sure you turn power off first as there are several areas in this area that can "bite."
3) Look for heavy frost / ice buildup in the freezer compartment. Defrost if necessary.
4) Make sure the fan is blowing in the freezer compartment.
5) Make sure there is air flow from the vent at the top of the refrigerator compartment. This air is driven by the fan in the freezer (most models).
6) Loading a lot of unfrozen food into the freezer compartment will have the appearance of the fridge going out, but is actually functioning normally as it removes heat from the food so it will freeze.
7) Your thermostat is not working correctly. Move it to the coldest setting if not already done so. Listen for the compressor to kick on. If it doesn't, bad t-stat.
Thanks
Jul 12, 2010 | Frigidaire FRS26KF6E Side by Side...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
My refige is warm and my freezer is frosty
lg american fridge freezer my fridge is working ok but my freezer isnt can u help please ty
Dec 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
265 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
