Question about Intel D845GRG Motherboard
Intel D845GRG Motherboard Problem:usb wiring conection to board
Intel d845 grg
    President:
  • 2,351 Answers
Hi mrm291048,
The Intel D845GRG MB supports USB 2.0 & is backwards compatible to USB 1.0
For in-depth description of motherboard wire color & location click on this link & scroll down till you see, "Standard USB Cable Wiring Color Code". http://www.usbman.com/Guides/BelkinMotherboard_cable_assembly.htm
You'll also need to open your manual to page 68 If you need the manual for the D845GRG MB click on this link; ftp://download.intel.com/support/motherboards/desktop/D845GRG/BVRG_English.pdf
Between the two you should be able to set the correct colored wire up to its matching pin on the MB.
If this is not answering your question, please set me strait & rephrase the question.
Mike
Posted on Oct 03, 2008
HII I have intel D845GRG mother board & i download drivers for it from intel site & it correct but sitll it is not support what is the problem
You need to download your motherboard driver according to the operating system you are using. Otherwise it will not work properly.
Jun 03, 2011 | Intel D845GRG Motherboard
Necesito los drivers de ethernet D845GRG
Drivers for Intel D845 Chipset are available at Intel Official Site
Click here and select "Operating System" and "Type of Download". From the list choose the drivers you need.
Good Luck!
Hope this helps!
CreativeTECH
Nov 05, 2010 | Intel D845GRG Motherboard
I need motherboard drivers for intel D845GRG model
Intel Download Center. You'll need to select the Operating System you are using. Good luck
May 15, 2010 | Intel D845GRG Motherboard
Intel D845GRG Motherboard Display drivers for Window Vista
According to Inel this board does not support Vista. They have no drivers available. Sorry.
Mar 08, 2009 | Intel D845GRG Motherboard
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Conecting front panel wiring to INTEL 845GRG MOTHERBOARD.
Normally a small area of 10 pins or 9 one is not used,you nedd the book or go to manufactuers website and download user manual,connect your wire to the board with out a diagram and you could damage the board
Jan 15, 2009 | Intel D845GRG Motherboard
Download motherboard driver of intel d845
i lost m computer drivers cd . so please send me intel d 845gv mother board drivers
Oct 12, 2008 | Intel D845GVSR Motherboard
Mouse not working after BIOS upgrade on Intel D845GRG motherboard
use usb mouse
othervise re format yours whole system low level
and re install win xp or whataver you want
Dec 14, 2007 | Computers & Internet
Intel D845GRG Motherboard Logo
266 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
