Question about Vizio VM60P 60 in. Plasma TV
Vertical red line on my Vizio plasma
I have a Vizio 42in plasma which is probably a year or two old and a vertical red line (about a inch wide) started appearing recently. Can anyone please help.. Thanks.
  • 1 more comment
  • jeritude Oct 19, 2008
    I have the same problem, red line on left side of screen , I'm thinking it may be a bad connection as it comes and goes, but where to start? does anyone know how to fix this?
  • diane_alley Dec 09, 2008
    Same with my 42" Vizio LCD. Started today ONLY 6 DAYS OUT OF WARRANTY!!!! Great, Sams Club won't replace it and Vizio "ESTIMATES" a charge og around $900.00. Well guess what? The tv cost $897.00 so they can stick he Vizio you know where. Do the math. It's cheaper to rent than buy as rental won't cost $90.00 monthly average that you pay before the tv crashes.
  • johnl1950 Jan 25, 2009
    I have a 42" Vizio plasma with a blue stripe on the right side of the screen.
    New Friend:
  • 22 Answers
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at Electronica-USA.com, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
Posted on Dec 23, 2008
  • Jim Chang
    Jim Chang Dec 31, 2008
    Update:
    Spoke with PartStore.com, rep stated 6871QCH038C (038C) is the superceded replacement for the defective prone OEM 6871QCH038A (038A). They and others offer the 6781QCH060Q (060Q) for $50 - $100 more. I opted for the 038C, but I was concerned about the title of the part which states "HAND INSERT"... PartStore.com rep stated it is in fact a board and there is no soldering needed, just "plug and play". DONE, paid only $120.95 + next day shipping for $29.95.
    Since I took the TV apart before, it was a breeze and took about 2 hours, start to finish.
    Important note, remember to remove the two 1" square spunge type heat sinks/pads the new board needs those for a proper installation and protection of the certain component.
    Also you need two small zip ties to replace the ones you are going to clip off.
    Added Bonus, the new board fixed other issues:
    1. At times I would get a squeegly red line go across the screen. I thought it was the source (cable) but it is gone now.
    2. Screen Shift, when I use the XBox for Games or DVD/HDVD the screen would shift. Very annoying, prior to swap out, recently the screen started to shift watching cable. Now it is no-longer an issue.
    I am really pleased with my DIY repair and wanted to share.
    The damn Vizio Out of Warranty Service wanted $360 for a service call which included the part for $125 plus they take my bad board for exchange.
    6871QCH038C $120.95http://www.partstore.com/Part/LG+Electro... h/6871QCH038C/New.aspx
    Over Night Shipping #29.95
    DIY FREE
Sss
Posted on Jun 27, 2010
  • cside702 Jun 27, 2010
    THANK YOU ALL FOR THE HELP & HERE IS MY CONTRIBUTION BACK FOR FUTURE
    Do-It-Yourselfers
    Just letting you guys know that the part
    that fixes the red vertical line works!
    Partstore.com was great
    and it was easy shipping and install as well. I took pictures of the
    interior once the back metal panel was removed. Here are some tips on
    doing this from what I wrote down for others that will be wanting to fix
    the TV themselves.
    1.Remove all screws from back of TV panel
    (yes even the small tiny ones near the bottom)
    2.Remove 4 tiny
    screws around the input box area
    Lift input box area straight up
    vertical and it will unseat from the two plugs under it, then remove
    exposed tiny screws
    3. Lift the back metal panel off the TV
    completely and vacuum dust that has collected on it and lay it some
    where that wont be disturbed.
    4.Take a picture if possible so
    you reference where screws go and posts go.
    At this point you'll
    freak out for a moment because you can't see the board that you need to
    replace; don't worry, it's hidden under the main board that would be
    right under the input box that we just removed.
    5.Remove back
    support metal bar by removing two screws left and right.
    6.This
    is where you need to be patient and remove the top main board by
    disconnecting the plugs and screws that are the grounders.
    If
    you have made it this far into your project, you can handle it from here
    I suppose, as this was my first time without any help or diagrams.
    Please take a [picture for re setting the parts back in place so you
    don't forget where they came from.On a scale of 1 to 5 (5 Hardest) I
    personally would say this is a 2 and only because there are so many
    screws, ha ha.
    At this site I posted a pic of the inside with helpful tips too
    http://forum.ecoustics.com/bbs/messages/...
    PART IS:6871QCH038C
    Cost: $120.95 plus what ever you prefer for
    shipping
2 Suggested Answers
  • 1779 Answers
SOURCE: vertical red line on my Vizio plasma
If the line is horizontal then it could be a y-drive panel ( depending on from ctr where it is ) whether it is the upper or lower board. Time to let a service company look at it, don't wait, more damage is possible the longer you play it.If it goes vertical ( up & down ) then it could be one of two buffer boards.
Posted on Feb 18, 2009
Red line down middle of television
Try putting a litte pressure on your screen where the red line is,if it goes away then check for a loose pin connection where that line was...
Sep 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
My Vizio Plazma 42in hdtv has a 2inch red verticle stripe on the left side and now the right side of the screen. It is a 4 year old 2400 dollar set I go at Costco.
Hello
This is most likely being caused by capacitors in the power supply changing value. Take it to a reputable repair person.
Good luck
Sep 23, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Feb 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VM60P 60 in. Plasma TV Logo
3,475 people viewed this question
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
