Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink system failed and pump stalled
After getting paper jammed in my printer there is an error message saying ink system failed and pump stalled
    Sergeant:
  • 352 Answers
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 12, 2008
We have a Canon Pixma MP280 printer and are getting an error message 6. How do we correct this.Please advise. Thanks!
r u sure that is e6?
There are bunch of error code for canon.
Pls check below and re-list your exact error code and can help you.
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 ? Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error ? USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error1
Apr 26, 2011 | Canon PIXMA MP180 All-In-One InkJet...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
Message says; Paper jam. There is no paper in it. Tried turning off and back on, resetting. Nothing, same message. Any ideas? Thanks, Niki
Open the back door and look in the middle of the back cover, there's a black plastic sensor lever that must move up and down freely as the paper passes. That lever gets sticky and needs to be cleaned with alcohol so it can move freely again. You may need to remove the back cover with 2 phillips screws to gain access.
Please rate my response!!
Jan 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Printer says there is a paper jam and there is no paper in there.
first thing you need to do is will do the overriding the error
1. open the pritner access door fo the printer
2. if the printhead or ink cartirdges already in center remove the ink cartridges and the printhead
3. If the printhead already removed close printer access door., Turn Off the pritner then after 10sex turn It own.
4. Now your pritner should detect no printhead installed not paper Jam., If you still recieved paper jam error without the pritnhead installed you need to have a printer replacement call kodak toll free number 1 800 421 6699 ext 05
5. Now if the message is pritnhead not installed., reseat the printhead and the ink cartordges then close the pritner access door., If your ecived same message paper jam., You need to replace the printhead you may also call kodak 1 800 421 6699, and have your free printhead replacement.
Most of the time overriding the error message solve the problem
Nov 17, 2009 | Kodak ESP 5 Printer
Ink system failure
All Asserts beginning with "0xC18A"
Replace Unit: unit can not be recovered or is almost certain to fail again.
It is a issue if your unit is in warranty HP Will relce it free of cost for you or you can check for any upgrade options with HP 1800 474 6836
Good Luck
Aug 29, 2008 | HP Photosmart 3310 Printer
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Paper jam error message
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Apr 21, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
187 people viewed this question
Ben Johnson
