Power supply for a sansui DVD player
Hi
I gave a funny technician who stole components from my power supply. the model number is RZ-9330AVD and the power supply has Code number DPPB-10077B written on it. The components missing are transistor PQ152, capacitor PC 169 and capacitor PC 171. I have no idea what component numbers they are. Please help
  • 6 Answers
SOURCE: My TH-C20 dvd player does not come on after a
Solution
Please find below the circuit diagram for yor reference.
Posted on Mar 14, 2011
CLUEPATEL
  • 138 Answers
SOURCE: HTS3300 Home theater system
It cant be know like that way! you need it to be repaired at service station only so they can trace it out!
Posted on Dec 08, 2007
sids8065
  • 61 Answers
SOURCE: DVD Player
The blown fuse is caused my an overload in the circuit. It can be caused by a faulty component or just some short circuit..Yes, if the fuse has blown off, there is a "chance" that componets inside may be faulty which caused the overload in the first place.
Posted on Mar 03, 2008
SOURCE: bose lifestyle v20 sound but no video
The problem turned out to be the TV itself. Somehow all the a/v and component cable inputs on the back of the TV got disabled. After finding then consulting the TV manual online (the TV is about 8 years old), we found there was a way to reset the TV to its original factory settings. Voila, the a/v and component cable inputs were enabled again, and everything worked correctly afterwards.
Posted on Oct 01, 2008
welcomejee
  • 10594 Answers
SOURCE: MI SONY COMPONENT DO NOT PLAY ANY CD. HCD-EP707
Please intimate exact model number of Sony home theater system to find out laser block part number info.
Posted on Aug 24, 2009
Why my dvd player by Philips model number pet702p/37 want charge when I plug it in the red light comes on and goes out after a few minutes but it won't charge what do I need to do
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 27, 2016 | Philips Televison & Video
My sansui dvd doesn't switch on at once it needs to be switched on and off several times for it to be on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market
Jun 04, 2016 | Sansui Televison & Video
How do I set up my DVD player DV-X2820 it is playing the DVD but I have no picture showing on my TV
May I know the model no. of your TV, what are you using for the connections (RCA cord or HDMI)?
Let me know to assist you further.
Jdvillanueva
Mar 27, 2011 | Sansui RZ-3200AV
Hi i have a sansui dvd recoder/vcr vrdvd4005 i need a remote do you know the model i need thank you?
Mine has no model number. But on the front down in the right hand corner is this number.......................076NOHQ010
Jan 30, 2011 | Sansui VRDVD4005 DVD Player/VCR
I am fixing a sansui rz-5000av receiver /amp. the problem is the power supply,it does not switch on. the fuse is fine, capacitors are all ok. But power does not reach connector for the standby supply to...
So you're saying ac doesn't get very far into the unit. THAT should be easy to diagnose with CARE since ac is usually passed unmodified to the fuses and power supplies, maybe through a relay. Get a digital voltmeter and find out where it disappears after getting into the unit.
Dec 31, 2010 | Sansui RZ-5200AV Receiver
Solution for "code for unlocking a sansui VRDVD4005?
www.dvddemystifiziert.de/codefree_en/sansui.html
http://www.dvddemystifiziert.de/codefree_en/sansui.html
Sansui CDVD1900 / CDVD9000 / DVD 512 / DVD 939 / DVD 967 / DVX 2000K / DVX 2900 / DVX 3050PH / RZ-7100 / RZ8700AV / VRDVD4000 / VRDVD4001 / VRDVD4005 / VRDVD5000no known hacks
Apr 17, 2010 | Sansui VRDVD4005 DVD Player/VCR
Where can I get an instruction manual?
good luck. maybe easier if seperate components model numbers
Jul 23, 2009 | Audio Players & Recorders
Where to replace burnt out PCB.
ok if you check the board-boards and replace all
the caps that have vented (expanded) with new ones. you may be in good shape then!
Jun 19, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Replacing MRI511 transistor
You need to replace complete power supply with following part number..
1-468-742-12 POWER BLOCK (HS8S2U)
Power supply is available in Part Store.
Part MR1511 can not be available and power supply of DVP-NS325
should not be repaired on component level.
Jan 22, 2009 | Sony DVP-NS325 Multi-disc DVD Player
320 people viewed this question
 Grubhead
Grubhead
