Question about Sony KV-24FV12 24" TV
Sony Picture Squeezes In On The Sides
The picture on my Sony TV model KV-27XBR55 has started squeezing in on the sides. It squeezes in, then out like an accordian. Any help on how I can fix this would be greatly appreciated. The Video display squeezes itself to the left corner of the screen. Then it switched itself off and never came back on...What do I do???
  • redz38
    redz38 Oct 01, 2008
    Thankx for the feed back. I brought ot to a technician explained th problem and it is being repaired as I type BIG help jingjao?!!
    Champion:
  • 252 Answers
Check the capasitor near the plyback, the value is: from 160volts to 250 volts
Posted on Oct 01, 2008
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Sony Picture Squeezes In On The Sides
Your TV has dry solder joints in "Pin Cushion" area, Its part of Horizontal deflection stage in TV and it requires resold work.
A tech person will understand above technical advise easily.
Need further info, let me know please.
Posted on Sep 30, 2008
The left and right sides are black and the picture is squeezed into the middle on the screen. i think it is called pin amp
This problems the Horizontal IC is dead and some of it capacitors too.Might even have the FBT dead too.If still have the same problems,after the "H" IC and those capacitors are replaced.
Sep 09, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA TV Model F36650
bad electrolytics vert circuit.
Nov 20, 2008 | RCA F36650 36" TV
Picture horizontal problems
There is a sevice menu but it is something a repair man has to adjust. Even to get to that menu is a matter of procedure. If the picture is not always squeezed down then adjustment is not the problem. If it is intermitant it could be a bad solder connection on the main board.Sometimes a bad vertical ic and leakey capacitors can be the problem..
Bottom line is there is not much you can do to correct the problem. You are going to need a service man
Nov 14, 2008 | RCA F36650 36" TV
Sony tv picture problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Oct 25, 2008 | Sony KV-40XBR700 40" TV
Sep 30, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
3 inches missing on both sides
Sounds like it is a widescreen TV stuck in standard view mode. Should have a menu option called widescreen or movie format.
Do you see the whole picture squeezed down or is it actually cutting off the sides of it?
Jan 08, 2008 | Proscan PS32125 32" TV
Picture squeezes in and out with a red and green halo around perimeter.
Convergence problems you can get help at PTS 18008447871 or more info at ctechnicians.com
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Picture is squeezed into the top part of the screen and black below. Sound and color are fine.
1) Solder pins of vertical output IC.........
2) Replace IC, if needed...................................T.
Nov 10, 2007 | Sony KV-27S20 27" TV
Picture bigger than screen
This can be caused not enough high voltage going to the picture tube. If the picture seems to get larger and smaller depending on the brightness of the scene on the screen that is probably what it is. IF that is the problem, there isn't much a normal consumer can do.
Nov 08, 2007 | Samsung TXF2899 28" TV
Sony KV-24FV12 24" TV Logo
190 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
