Question about Toshiba 62HM15 62" Television
Toshiba 62hm15a- bright flashes
My toshiba 62hm15a tv has a problem. First there started being like hot spots on bright areas on peoples faces etc. Like something wasn't regulating where there was more light on the screen. Then it started having bright flashes across the screen, the bulb was on low and when I turned it to high the flashing stopped for several months. Then it got worse and the flashing starting to include like horizontal lines when it flashed. Could you tell me what is going out on this thing? The lamp "looks" ok still. Thanks
My toshiba 62HM15A has bright and dark flashes.
Posted on Jun 21, 2009
Bright Spot
A fixed blue area on screen may be a display panel (main screen unit)
Here is a link for the boards etc this set uses--take your pick:
http://www.shopjimmy.com/sceptre-x460bv-f120
May 17, 2012 | Sceptre 46 X460BVF120 LCD TV
Flashing screen on Toshiba 42HP66
Plasma sets use high voltage to produce their displays and it sounds very much like the HV supply is losing (or has lost) regulation likely due to the impending failure of a semiconductor.Check to see if Toshiba has any extended warranty on this since it could be a series problem.If there is none, ask for a price on a new or repaired supply on an exchange basis.
Dec 30, 2011 | Televison & Video
My Philips tv model50PL9200D/37 has hot spots in the picture.It doesn't matter what picture setting or adjustment it is on.Dark scenes show purple in some places.Light scenes show bright spots especially...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Will a light from a 62HM196 work on a 62hm15a
I looked up both models and both tv sets have different part numbers so probably not!
techman
May 04, 2010 | Toshiba 62HM15 62" Television
Purple spots in the bright areas in my LCD TV
If garanty period is available , then you should return it for another.
Nov 05, 2017 | Toshiba 42HP66 42 in. LCD Television
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Bright spot on my 52hm95
can see it in certain lighting and even when the TV is off! It will appear lighter than the surrounding areas at times and can be annoying. I called Toshiba and had a service man come out and even though he acknowledged that this is common, Toshiba will not replace the screen.
Feb 11, 2008 | Toshiba 52HM95 52" HDTV Projection...
Flashes bright white randomly
resolder the tv circuit in the power supply and the flyback area that will solve your problem as the symtoms are intermittent just some loose components due to consistent heat over the years.good luck.
Jul 27, 2007 | Toshiba 34HF84 34" TV
Screen spot
Since you have a black spot,you need to look at the mirror or inside screen. If it were a certain color, like purple or yellow, for instance, I would suggest a lens or picture tube, but, since it is black in one spot, I would suspect debris in those areas.
Dec 12, 2006 | Toshiba 51H84 51" Rear Projection...
Toshiba 62HM15 62" Television Logo
440 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
