THE TV IS SHOWING DOUBLE, WITH THE DOUBLE BEING RED. JVC PROJECTION TV, 56"
  • 4,234 Answers
This is a convergence problem that you should be able to fix if you can solder. Please post the make and model. That info will allow me to give you more details and instructions.
Thanks,
Dan
Posted on Sep 30, 2008
Our tv is showing double images.
if your set looks anything like the attached photos I can tell you what is involved in repairing it.
Before you rate this information let me know if pictures look anything like your problem.
SD TECH
Jul 28, 2011 | JVC AV-56P575 56" Rear Projection...
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
Double faces with red 'halo' around people...after TV 'popped' and went off then back on.
Replace the convergence ICs and resistors. You can get the JVC repair kit called the AV48WP30 - AV65wp30 convergence repair kit from www.tvrepairworld.com which contains the ICs, Resistors, and the CD with repair instructions.
May 25, 2011 | JVC AV-56WP30 56" Rear Projection...
I have a 56" JVC AV-56WP30. It shows two pics one red and one green. what is wrong and how do i fix it
The LCDs in the tv are in 3 colors, Red, Green and Blue. They are out of alignment. Repair needed.
Aug 09, 2010 | JVC AV-56WP30 56" Rear Projection...
I have a jvc av56wp74 double immages in red and
Ur tv have convergence problems,it dead.U must have soldering tools and know how to solders to fix the convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 05, 2010 | JVC AV-56WP74 56" Rear Projection...
Our TV is showing double images
Due to failure of convergence out section in rear projection TV, it gives double image on screen.
Replace convergence out ICs on main circuit board of TV to fix this problem.
Let me know if you want to fix TV by yourself and you have electronics repair tools and knowledge to follow instructions., also confirm TV model and brand to provide you more technical info.
Thanks.
Nov 28, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC 56 inch projection AV-56WP74 red color not aligned
I have the same tv set and about 4months ago Ihad the IC STK392-110 replaced. I was told that it was the most common problem with proj. tvs. It did solve the probem until last night when I went into the menu to change a audio setting and stupiditely accesed the convergence setting and decided to do an auto adjustment which mesed up my beutiful HD picture. Now I have the red out of alignment ad even after I did a reset and multiple manual adjustmets it is still off at the top and bottom af my screen.
Dec 27, 2008 | JVC AV-56WP74 56" Rear Projection...
TV PROBLEMS
If the images are different colors (red,green,blue) then the convergence has diverged. Some TV allow re-convergence through the menu screen, older sets my need to be physically adjusted (aimed) to clear this up. a strong knock to the TV may have cause this.
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc av56wp74 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Double vision On JVC AV-56WP74 56
You have an convergence problem, There are 2 IC's that go bad and a few resisters that can change value. If you flip the board with the Chips inspect the pins for cold solder joints. The IC's can be purchased from matelectronics
Jun 17, 2007 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
