Question about Thomson Televison & Video
I have an RCA DLP Model# M50WH72SYX12 in my shop. I replaced the colorwheel and lamp and set goes on and just shuts down. do you know how i get a hold of RCA tec line??
5 Suggested Answers
SOURCE: sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Posted on Apr 11, 2008
  • 2326 Answers
SOURCE: color blinkig in and out.
It seems like the color wheel might start to fail.
Do you hear any abnormal sound(s) from the TV when ramdon color appears.
Would you be able to check and make sure all the fans are working properly?
Posted on Jul 16, 2008
SOURCE: model #m50wh72syx12.... sound but no picture...
I have the same problem, TV is only 3 years old. Already replace bulb once and helped for a little while. The more I check, this sounds like a very common problem. Hmm...maybe a class action suit?
Posted on Oct 14, 2009
  • 65 Answers
SOURCE: I have an RCA M50WH72syx12, 50" DLP.
Yeah could be expensive if it isn't the lamp.
Mind you could be a little easier, might just be a fuse on the video relay. If you are confident in being able to open it up, check the relay that runs from the video input to the power capacitors and there should be a small fuse along that circuit.
If the fuse has a broken capsule then you may just be in luck. Failing finding a broken fuse, then I would agree with you on the bulb. But check the blub for any markings or cracks because they usually only make noise when the vacuum fails.
Hope this helps and good luck mate! :D
Posted on Nov 23, 2010
Nov 23, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I just replaced the lamp in my xr-11xc sharp projector, reset the timer, and it turned on. after shut down, i tried it again, and now the standby light comes on, i hear the fan spin up, then the lamp...
the colorwheel may be bad. if it doesn't spin, the lamp won't strike. if the colorwheel is ok, replace the power supply/ballast. you can get one and do it yourself, or send it to a sharp service center. either way, try www.avsolutionsny.com. they're really good.
Jan 27, 2010 | Sharp XR-11XC DLP Projector
Rca 50'' dlp model # M50WH92S turns off, light blinks 3 times
Replace your LAMP if all of your Fans are running! If lamp fan is not running Lamp will not turn on .Call FOX for Lamp 1-800-227-5369
Dec 25, 2009 | RCA Televison & Video
Samsung hlr5067w shuts of after 30 seconds... flashes red
I would suspect the lamp first as they can cause intermittent shut down issues.
Nov 03, 2009 | Samsung HLR5064W DLP Projection TV
Model #m50wh72syx12.... sound but no picture...
Sep 28, 2009 | RCA Televison & Video
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Humming fan
ok it could be a fan...or a colorwheel...turn the tv on....let it power all the way up...then shut down ...you are listening for WHEN the noise stops...does it stop when the lamp powers down..look @ the back to see this..if it does then it will need a colorwheel..if the noise is there for 5-10 minutes after lamp has shutdown then it is a fan...problem: there are 3-4 fans in the tv...which one is the next question...let me know what you find..
Sep 09, 2008 | Televison & Video
Color blinkig in and out.
Jul 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Televison & Video Logo
71 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
