Question about Linksys WPSM54G Print Server
Useing Linksys wpsm54g with tcp/ip
You replied to my question on the print server to use tcp/ip since I am a dummy at this how do you do that? I have the ip address of the print server but when i tell Windows xp under new Pinter's it says something like invalid ip or can't find. any help will be much thankful. no faxing,scaning or copying will be fine since the printer i want to use is just a color laser pinter. the server works fine with the "approved" printer. Thank you
7719c
    Genius:
  • 1,689 Answers
That will depend on the IP address of the print-server and the network, specially if the printerver is not set to a static IP, you may get communication errors when you try to use or install the printserver.
you may try to set the PS to have a static IP address or you may use the printserver name instead of its IP address.
use custom settings then use "RAW" after that chnage the queue name to p1 or l1.
there are many work arounds for this kind of limited configuration, but i would strongly suggest you call Linksys Toll Free Tech support for more configuration
Posted on Oct 01, 2008
Trying to install wpsm54G and I'm stuck on step J. Unable to find printserver.
Hi could you tell what is the main Router it should be compatible with your main router to get the IP address then you can install and share the printer over the network should you need any help please contact me on my website http://computernetworksupportindubai.com/
Jul 22, 2011 | Linksys WPSM54G Print Server
Can't connect to WPSM54G after configuring it
hi sir,
1. first reset the printserver
2. make sure that the printer drivers are installed on the comp.
3. use a w/l comp on which we can go online
4. connect the w/l comp to the print server using ethernet cable and also connect the printer to the print server
5. put the print server cd into the comp and run setup.
6. make sure printer server is near to router and there is no firewall on the comp.
7. the setup will give the ipaddress to print server if not plz assign static ip on the printserver.
8. follow the wizard
9. it will ask u the w/l settings to enter. plz type the exact same n/w name and security password.and apply the settings.
10.after that it will connect u to the print server and u will be able to print if you will not u will find an error to open port.
11.you need to open standard tcp/ip ports for the printserver ipaddress that u have assigned.
12. if u dont knw, u can ask the comp vendor.
13. plz also confifm that the printer is compatible with ur print server.
thanx and regards
sukhiii
Apr 16, 2009 | Linksys WPSM54G Print Server
Cannot see WPSM54G wireless router after configuring it correctly.
It's pretty sad. This device doesn't support Mac and apparently it doesn't support Windows either! I expect a lot more from Linksys. It seems like this is a common problem yet they offer no clear solution on their web site. Do you think maybe Linksys is going out of business and isn't going to support their products anymore?
Apr 13, 2009 | Linksys WPSM54G Print Server
Cant find print server to configure the IP on our network
you can change the IP to ur print Server
or u can type
ipconfg in cmd
and u find the IP
in print server
or send the type off machine and i tell u how u can change the IP for the printer
Nov 28, 2008 | Linksys WPSM54G Print Server
Linksys Wpsm54G print sever
about installing the printserver, you can actually make this work using TCP/IP, so that the print server will not be driver-dependent, just the connection.
BUT, using TCP/IP will only allow you to print through the printserver and not COPY, SCAN or FAX through it.
if you have other questions just lemme know
Sep 12, 2008 | Linksys WPSM54G Print Server
Initial setup no password
use-ly it is user name is (admin) password is (admin)
Jan 09, 2008 | Linksys WPSM54G Print Server
Linksys print server Model EPSX3
Firmware upgrade for your print server could fix your problem or kill your print server.
Try this first: SET UP A STANDARD TCP/IP port.
Set a static ip on the print server. Use that ip address to set up your STANDARD TCP/IP PORT. You can do this on the printers and faxes page.
Right click the default printer then click properties. You have to ADD A NEW PORT.
Good Day
Nov 05, 2007 | Linksys EtherFast 10/100 (epsx3/uk) Print...
Network printing
I am afraid, PSUS4 is an older model of print server , which supports only ordinary printers. All in ones are not supported by PSUS4. Linksys have other print server which works with all in one printers. The model number is WPSM54G. Probably you can try that. Also, if the PSUS4 is less than one month old, you can get it replaced with the WPSM54G from the stores itself . The WPSM54G can be used as wired as well as wireless to the router. If you want to use the PSUS4, you may need an ordinary printer like Office jet or laser jet with USB 1.1 version.- Thank you
Oct 26, 2007 | Linksys (PSUS4) Print Server
Linksys WPSM54G Print Server Logo
666 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
