Question about Polycom ViewStation ISDN (pcy220011323001) Video Conference
The unit will power down during conference by it self.
We have three know problems, one is the unit while in use will lose power, second freeze while in use and third can receive calls but not make a call.
  • Anonymous Apr 20, 2009
    Polycom Viewstation spontaneously reboots in the middle of a conference. Re-connect, and it last approx. 5 minutes before rebooting again. This is using IP videoconferencing.
    Problem Solver:
  • 7 Answers
Which exact unit ? This is a known problem with orignal 'Spider' PSUs for the Viewtation range (reboot issue).
Posted on Jan 14, 2009
What are possible reasons that the conference phone is not getting power?
If you know anyone that can test the power supply with a digital meter, you can check if the power supply works or not. the power control board on the voicestation might have blown. and If that is the case I wouldnt recommending fixing it. Getting a refurbished or used with maybe 3 months to 1 year warranty isnt that expensive on these systems. getting it fix might cost you about the same. But checking if the power supply is working or not would be the first thing you want to do. If that works. looking for a power supply is pretty easy.
Feb 27, 2012 | Polycom VoiceStation 300 Conference Phone
How can I make conference call or joint call fron vtech cordless phone
To make two-party call on your Panasonic phone and ask the person on the other line to wait for a moment.
  • Check to see if your Panasonic phone has a flash key feature. If it does, press the flash key down and wait until you hear the confirmation tone. If the Panasonic phone you're using does not have a flash key, hold down the the hook switch for half a second, then release. Dial the number of the third person in your conference call. If you're inviting someone in-house to be a part of your conference call, dial their extension number instead. If you're dialing an outside line you may need to dial 9 before dialing the number.
  • Wait for the new addition to the conference call to answer and then press the Flash key again. Wait an additional two or three seconds before pressing the number three on your telephone keypad. Start your conference call. Once you've pressed the flash key followed by the number 3, as in Step 4, your conference call is established. If you wish to add additional participants simply repeat Steps 3 and 4.
    Regards
  • Jun 30, 2011 | Vtech Cordless 6041 Phone
    This unit will not turn on, we have checked the cables and fuse on cable. the unit has been used for 2 months, during that time it turned it self off a few times. we purched it 2 years ago, the vessel...
    GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
    Jan 26, 2011 | Garmin Gpsmap 4012
    The router was working fine yesterday. I checked it today, and it isnt working anymore. I unpluged it, and plugged it back in, and no indication lights are illuminating. I have tried this several times and...
    Step 1 Locate the reset pinhole on the back of the unit.
    Step 2 With the unit powered on, press and hold the Reset button.
    Step 3 Hold the Reset button for about 10 seconds.
    Step 4 Release the Reset button.
    Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
    Step 6 The device is now at factory defaults.
    Note: Do not recycle power during the reset procedure.
    When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds
    Dec 16, 2010 | Belkin F5D8236-4 Router
    Three party conference call
    Once you receive your first call Press conference button. your first call will automaticaly be on hold. Press a line button to dial second number. Once call is connected Press conference button and you will have 3 way conference.
    To add more PeoPle into conference Press conference button again and select a new line. Dial the number and Press conference button to connect everyone to that conference.
    HoPe this helPs
    Jul 17, 2009 | AT&T Lucent MLS-12D Phone
    Help
    Hi Raja,
    This means there is an error during POST (power on self test). Please refer your manual for the error codes or light codes. If you can manage to access the machine diagnostic menu please do. Like from off position and pressing combination of buttons holding for 3 to 5 seconds and powering it on.
    Best regards,
    Rosener
    Feb 05, 2008 | HP LaserJet P2015dn Printer
    Samsung rs2578sh
    Yes, you have a faulty defrost heater or thermal fuse, the fault will re-occure within a few weeks. Regards Advisor
    Aug 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
    Camcorder "Freezes Up" during playback and/or during creation of thumbnails
    I had the same problem - you are (as I was) turning off the camera too soon after you hit the stop button after recording a scene. Wait until the word "disc access" appears (about 5 seconds after you hit the stop button. This "marks" the end of the scene. I just don't know how to edit that scene out or if it will delete it out. I know after finalizing the disc that scene will pause for a while (10 to 20 seconds even) when you watch it through the DVD player to the TV.
    May 22, 2007 | Hitachi DZ-MV730A DVD Camcorder
    Unkown Beeping During Calls
    It is hard to tell if this conference phone is installed on a PBX or not? "At meetings" tends to make me believe that it is. Beeping can come from a few sources. If a call is being recorded it is necessary to provide a beep tone so that the parties on the line know that they are being recorded. This is a FCC requirement. You can ask the other party if they are recording the call. Beeping can come from call waiting. It is recommended to turn call waiting off unless you are bridging incoming calls. If a call is on hold you will get a beeping tone. You can check by pressing the flash button and see if there is a second call. If so hangup and your original call should return normally.
    Mar 21, 2007 | Polycom SoundStation 2W (2200-07800-001)...
    Polycom ViewStation ISDN (pcy220011323001) Video Conference Logo
    365 people viewed this question
    Top Polycom Lands Phones Experts
    Gerald Ridge
    Gerald Ridge
    Level 1 Expert
    David Burbee
    David Burbee
    Shehu Pro
    Shehu Pro
    Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
