Question about Yamaha RX-V995 Receiver
Yamaha RV1103 receiver
I just moved. The moving company disconnected my surround sound. HELP! i have a Philips 42" plasma TV mod 42PF5321D/37 and i am trying to connect the yamaha RV1103 receiver to it as well as my speakers to the receiver. Hellpppp!
Thanks
K
  • zoii Sep 30, 2008
    well i have three connectors. and all the connections on the tv say audio in. also the wires from all the speakers, i am really technically challenged. Thanks for trying though. I can connect my dvd player to my tv and everything works, except the surround sound of course.
YOU SHOULD BE ABLE TO RUN SOME PHONO LEADS TO THE AMP FROM THE CONECTORS ON THE BACK OF TV THE SOUND CONNECTORS ARE USUALLY WHITE AND RED JUST CONNECT THE CORRESPONDING LEADS TO THE SAME COLOURED CONNECTORS ON THE AMP
Posted on Sep 30, 2008
42" Plasma 42PF5321D/37 will not power on. I replaced the fuse on the power supply board with a 3 amp (that's what it looked like, but I'm not sure it was the right size because it was burned
Always replace fuse with fuse value required If fuse value is less it will burn out . If you replace with fuse that is required and it burns out then you have bad short in power supply circuit In that case check bridge rectifier
Dec 07, 2012 | Philips 42PF9630A 42 in. Plasma Television
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
42 Philips Plasma 42pf5321d/37 green light on no AV no Menu nothi
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung, Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H. 2nd more of a long turn approach to your system. You might look at a Power conditioner to ensure constant clean Voltage & current to your Set, Price I know running about $150 to $200, but this will protect your set from a Spike and under voltage swings from the 110V plug. Surge protectors only help the Spikes on the 110v Line not the Drops. Hope this helps
May 29, 2009 | Philips 42PF9630A 42 in. Plasma Television
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
May 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
No audio from cable through surround sound
you have to go to the setup for the TV audio and change it to audio out, not speakers.
May 07, 2009 | Philips Televison & Video
Where do i plug in to here my TV on my HtS3544
TV Audio Out RCA cables to Receiver's TV Audio IN
Apr 07, 2009 | Philips HTS3544/37 Theater System
No Picture just 4 red blinking lights
Look For TWO 10 Volt 33000 mfd. Caps That Appear To Be Swollen,They Are Next To Each Other At The Bottom Of The Power Supply Board, Change Them To 16 Volt Versions.
Feb 03, 2009 | Philips 50PFP5332D 50 in. Plasma...
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Yamaha RX-V995 Receiver Logo
107 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
