Question about Canon PIXMA iP90 Mobile Printer
1p90 remains offline
Eventhough I have changed cables 3 times every time I start to print I get the message the printer is offline.
  • Anonymous Oct 19, 2008
    offline msg.
  • 76 Answers
I have had a little board inside the machine the connects the usb lead to the logic board fail and this causes this fault. You will need to call out a canon service engineer to fix your problem.
if your in the uk i can give you some contacts .
Hope this helps
Posted on Oct 20, 2008
Help m fix my printer. I don't have enough knowledge to do it alone. I have been plugging all the wires that connect the printer and computer but yet there's still a warning that pops up and says...
ssue: ERROR: Printer is offline.
Solution: Set printer from Offline to Online
Set Printer Online If the printer is set Offline, an error message will appear and the print job will not complete. printeroffline.gif
  1. Open Printers folder:
    Windows 7 users: click here.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. Right-click your printer's icon and select 'Use Printer Online'. The document will print.
  3. If the document does not print and the job remains queued, a printer icon will appear to the left of the time on the Windows taskbar.
  4. Double-click on the printer icon to open the 'Printer' window.
  5. Click on the document title below the 'Document Name' column.
  6. From the 'Document' menu select 'Restart'.
1. Click the start icon, then click Devices and Printers.
2. Right-Click the printers icon and select See what's printing in the dropdown menu.
3. In the next screen click the printer tab. Use Printer Offline will have a check mark to the left of it. Click Use Printer Offline.
4. Close the window. The printer will now be used online.
Sep 01, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Myy Brother MFC5460 will not print at all. Printer status says it is ready, but the printer never receives the print material. The information remains in the print queue. Work Offline is not checked, so I...
How is it connected?
If its connected via usb cable just follow the steps below:
1. Make sure that Mfc5460cn lcd shows date & time. 2. Disconnect the usb cable from the computer and printer. 3. Turn off the printer and unplug it from the power outlet. 4. On the computer, cancel the document on queu. Go to printers folder and right click on the Mfc5460cn icon and left click on cancel all documents. 5. Reconnect the usb cable from the printer then to your computer. Make sure that it is connected securely. 6. Plugged the printer back to the power outlet and then wait for the lcd to show date & time. 7. Open the printers folder again. Make sure that the status is ready document 0 8. Right click on MFC5460cn then left click on properties. ON the lower left side of the window click on print test page.
The printer should print a test page. And it should work,
Hope this helps. Rate if it works. Thanks
Apr 09, 2011 | Brother MFC-5460CN InkJet Printer
Hello, my HP Deskjet D1560 goes offline every time i connect the printer to my Computer, i already installed the updated driver..... Kindly solve my problem Thank you
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Aug 02, 2010 | Computers & Internet
My printer says offline and files are in the queue
This issue occurs due to the change in IP address of the unit (Most of the IP addresses are Dynamic and it may change time to time. So the computer is unable to locate the previously set IP address and this leads to a message printer offline). I request you to set a static IP address for your printer and verify the result.
:) Dr Tony
May 25, 2010 | HP Photosmart C4580 All-in-One InkJet...
It is offline and will not print. Last print job
check the printer cable, try to change with other cable, or you can try to reinstall your printer driver.. hope these will help
May 04, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Offline
change the data cable of ur printer
Sep 12, 2009 | Brother HL-2040 Laser Printer
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Installed hp psc 1310 will copy great every time printer is turned on it prints test sheet, but will not print anything from computer the message is "user intervention required use printer...
Click START then PRINTER AND FAXES double click your printer when the printer windows open click PRINTER uncheck USE PRINTER OFFLINE i think that the reason why you cannot print because the printer is offline
Apr 14, 2008 | Computers & Internet
Canon PIXMA iP90 Mobile Printer Logo
178 people viewed this question
old marine
old marine
