Links in Outlook Express are dead.
I'm running XP Pro and using Outlook Express for email. The links that are embedded in my emails are dead. This just suddenly happened one day after an automatic update. No one seems to know how to fix it. Any ideas on this one.
  • 4 more comments
  • M D Boakes Oct 08, 2008
    Yes I am running SP3 and IE7
    I have had a look for the URL:Hypertext Transfere Protocols and it does not exist, the only file type I have for URL's is URL Internet Shortcut
    All files exept Mshtml.dll were sucsessful.
    It said 'Mshtml was loaded, but the DllRegisterServer entry point was not found. This file can not be registered'.
    The URL's are still not working, could this be the problem.
    I've done every thing on the list, no joy. Any other thoughts on the matter?
  • M D Boakes Oct 09, 2008
    I have had IE7 for a while and links in Outlook Express were working fine. It's only after an automatic update that it decided to suddenly change so I can't see that there is a conflict between IE7 and O/Ex6. I could be wrong but it seems to point to some change the last automatic update did, all we need to do is find out what it might be. Has anyone else had a simalar problem or has Microsoft itself had any problems of this nature.
    By replacing -nohome with %1 in both URL:Hypertext Transfere Protocol and URL:Hypertext Transfere Protocol with Privacy has fixed the problem. Just make sure that when Internet Explorer asks you if you want to make it your default browser click NO.
  • 10,594 Answers
Here is an idea, uninstall that update which caused that problem.
go to control panel, add or remove program menu, tick show updates, (Option )sort by date last used, find last update at bottom, click Remove.
yesterday, service pack3 stop my internet browsing. i did same thing with it. now i'm in peace and giving you solution ;)
Posted on Oct 08, 2008
    Top Expert:
  • Computers & ... Master
  • 77,186 Answers
I would suggest you use the System Restore feature in the windows tools to go back to just previous to the software update that caused this outlook problem, here is how you do that
1. Click start, select All Programs, from this menu select Accessiores, from the accessories menu select System Tools, in the system tools select System Restore, then restore from the restore calender to a date prior to the software update.
  • 19,396 Answers
Ensure that the mail format is set to HTML, if format is plain text , you cannot use hyperlinks.
  • 2 more comments
  • Ginko
    Ginko Oct 08, 2008
    Options item in the Tools menu.And select Send tab.
    There you set mail format to HTML:
  • Ginko
    Ginko Oct 08, 2008
    Just Change mail sending format, that is the first thing to check.
  • Ginko
    Ginko Oct 08, 2008
    Best solution?!....LoL
  • Ginko
    Ginko Oct 08, 2008
    Listen, the soluton you are following concerns Internet Explorer.
    You do not do not have the problem with web mail using Internet Explorer.
    The problem is probebly with Outlook Express mail format settings.
    If the format is plain text, you cannot insert links.
    Check settings following the instuctions I gave you before, here.
    Open Tools menu and select Options item in the .And select Send tab then change mail sending format to HTML, don't forget to press OK or apply .
    Keep us updated and let me know how it goes.
    Thanks.
    President:
  • 2,712 Answers
Are you running SP 3?
  • 6 more comments
  • Swilin Sampson
    Swilin Sampson Oct 08, 2008
    Try this:
    Go to control panel, folder options, file types tab
    Scroll down to the URL:Hypertext Transfer Protocols, click advanced, click edit
    and make sure the following is in the application used to perform action box:
    ”C:\PROGRAM FILES\INTERNET EXPLORER\iexplore.exe” -nohome
    The same applies for URL:Gopher
    DDE should be set to: “%1”,,-1,0,,,,
    Application should say: IExplore
    DDE application not running should be blank
    Topic should be: WWW_OpenURL
    Run each line individually.
    Start – Run then type
    regsvr32 Urlmon.dll
    regsvr32 Shdocvw.dll
    regsvr32 Shell32.dll
    regsvr32 Oleaut32.dll
    regsvr32 Actxprxy.dll
    regsvr32 Mshtml.dll
    If this does not work try System File Checker
    sfc /scannow (note the space) have your XP CD handy this time as you may
    be prompted for it.Hopefully that should work..
  • Swilin Sampson
    This can occur when another program has registered itself as the default application for browsing the web. If this program is not well written, or it has been uninstalled, outlook express cannot launch a browser window when you click on a link within an email.
    To remedy this problem you must re-register Internet Explorer as the default browser.
    1. Start Internet Explorer
    2. Select the Tools->Internet Options menu
    3. Select the [Programs] tab
    4. Look for a checkbox labelled "Internet Explorer should check to see whether it is the default browser"
    5. If this checkbox is not ticked, then this is the cause of the problem, so tick it!
    6. Click OK
    7. Close Internet Explorer
    8. Re-open Internet Explorer
    9. Close Outlook Express
    10. Re-open Outlook Express
  • Swilin Sampson
    You will have to scroll a bit down to find it.
  • Swilin Sampson
    Try this then:
    If not try the other solutions as well. Also try disabling any anti-virus software temporarily, and see if this helps.
  • Swilin Sampson
    Swilin Sampson Oct 09, 2008
    Ok, try these:
    1. Go into 'internet options' in control panel and make
    sure for the mail program your version of Outlook Express (OE6) is set as
    the default mail program.
    2. Click on Tools - Options - Security tab - In Security Zones, change the
    Zone from Restricted to Internet.
    3. Click on
    Tools - Internet Options - Advanced
    Use the RIES feature at the bottom. (Reset IE Settings).
    4. Uninstall any PopUp blockers or AntiSpyware software and any ToolBars like Google toolbar, yahoo Toolbar, etc..
    5. Found this from the Microsoft website:
    Hyperlinks do not work in Outlook Express after you upgrade to Internet Explorer 7
    IE7 seems to be having issues with OE6. If none of the solutions above worked (including other Experts' solutions), you have three options:
    1. Uninstall IE7 and revert back to IE7.
    2. Uninstall the SP3 update
    3. Use a different browser like Mozilla FireFox.
    Cheers!
  • Swilin Sampson
    Correction:
    1. Uninstall IE7 and revert back to IE6.
  • Swilin Sampson
    Oh, this is a common problem with IE7 and OE6. It doesn't happen immediately, but after a while. Just do a Google search and you will come across numerous such complaints. Just look at Microsoft's article:
    Hyperlinks do not work in Outlook Express 6 after you upgrade to Internet Explorer 7
    However, it could also be a bug in SP3. Simply go to add/remove programs in Control Panel and remove the update. Or else, downgrade to IE6.
    I would really recommend switching to FireFox. Very reliable and very few bugs. Please do try all the steps I've mentioned in my previous comment one by one. One of them SHOULD work.
  • Swilin Sampson
    GREAT!! Problem solved!
How do I make outlook express my home page?
try this,,,To ensure Outlook Express is Windows's default program for all things email:
  1. Make sure Outlook Express is not running.
  2. Select Run... ...
  3. Type "msimn /reg" (excluding the quotation marks).
  4. Hit Enter. ...
  5. Launch Outlook Express.
  6. Select Tools ' Options... ...
  7. Go to the General tab.
  8. Click Make Default under Default Messaging Programs.
More items...
Make Outlook Express Your Default Windows Email Program - Lifewire
https://www.lifewire.com/default-program-outlook-1173593..
or goto this link. How do make outlook express my home page Google Search
Oct 12, 2017 | Microsoft Outlook Express
I can't email my projects from Platinum 16 because I use Yahoo mail not Outlook Express. I also have a Gmail account but I don't see any way to change the OE default. I have XP Pro.
To make Outlook Express Your Default Windows Email Program :
1.Make sure Outlook Express is not running.
2.Select Run... from the Start menu.
3.Type "msimn /reg" (excluding the quotation marks).
4.Hit Enter.Wait for, say, ten seconds for the process to finish. Nothing will appear on screen. Do not let that disturb you.
5.Launch Outlook Express.
6.Select Tools ' Options... from the menu.
7.Go to the General tab.
8.Click Make Default under Default Messaging Programs.Click OK
Sep 16, 2011 | Broderbund PrintMaster Platinum Version 18
Answering craigslists adds
You don't need Outlook Express to sent or receive your Email if since you already have an Email account like Hotmail or any other online free Email Accounts. You can sent or receive your Email through Hotmail account.
Outlook Express is already bundled with WinXp when the OS is installed to your PC/Laptop. Unless you want to download your Email to Outlook Express and you need to configure Outlook Express to receive Email from your Hotmail Account.
Jul 10, 2010 | Computers & Internet
When I attempt to e-mail an article from yahoo to another contact, windows internet explorer links to microsoft outlook which i do not use. How can i link directly to my e-mail at boaks1661@yahoo.com?
unfortunately what you are referring to are Mailto: links, which windows XP defaults to an actual mail program instead of web based email. The only solution is to configure your outlook express to use yahoo
Nov 22, 2009 | Computers & Internet
I have just upgraded computers from windows2000 to xp how do i get my emails from outlook express on this computer
You will have to configure the account in outlook express again and after taht you can get your emails back in outlook because you have upgraded your computer and if you have back up of email then you can also import it. you can also use the link http://www.microsoft.com/windows/ie/ie6/using/howto/oe/setup.mspx go get the help to configure the account in outlook express.
Nov 13, 2009 | E-Machines eMachines Desktop PC
Cannot open links in outlook express
Please check the version of the internet explorer if it is 6
then go to internet options
clcik on programs tab
click on reset web settings
it will work
Sep 06, 2009 | Computers & Internet
Links from email don't respond when click on.
If you are using an on-line email service check your settings. It might be possible to enable that. If you are using software such as Outlook or Outlook Express enable the choice to receive and view your email as html or rich text instead of view as text.
Jul 17, 2009 | Dell Microsoft Windows XP Home Edition
My Outlook Express Won't work
Sounds like it's self explanatory. Perhaps Hotmail is no longer free for Outlook Express. If you would like to use Outlook Express as your defautl email client and use a POP3 based email account, may I refer you to www.hotpop.com? You can apply for a free POP3 email account which you can set up to run with your Outlook Express. You may also want to check into www.gmail.com. They support web based inboxes as well as POP3 configuration for your Outlook Express.
Apr 06, 2008 | Microsoft Windows XP Home Edition
I use Outlook Express on Windows XP... Can I snyc this?
Outlook Express - no software included with Palm devices but There is third-party software to synchronize the email and Windows Address Book from Outlook Express to Palm OS devices. Here is a relevant link: http://www.livepim.com/expressmirror/index.htm - address book conduit to mirror the OE address book to Palm Desktop
Sep 12, 2005 | Palm Zire 21 Handheld
Computers & Internet Logo
271 people viewed this question
David Payne
David Payne
